First Rocket build
studiodunn
Re: First Rocket build
Post by studiodunn »
M Fowler wrote: Tue Apr 07, 2020 2:25 pm Your Rocket combo looks good.
By the way that boost doesn't need a relay. I have installed the boost in many Rockets using just a standard Marshall single button switch.
In fact you can add the capacitor right on the pedal jack to ground.
Rockets take pedals very well and I never had a problem with reverbs or distortion pedals through the input jack of any of my Rocket builds.
Thanks Mark.
So I assume there is a way to just shunt the boost portion?
Colossal
Post by Colossal »
Mr. Dunn, I think Mark is referring to the Rocket Boost function as lifting the cathode bypass cap on the second stage only, not bypassing the second stage completely. But I will let him clarify. The original Rocket did not have a bypassed cathode on the second stage.
studiodunn
Colossal wrote: Tue Apr 07, 2020 5:07 pm Mr. Dunn, I think Mark is referring to the Rocket Boost function as lifting the cathode bypass cap on the second stage only, not bypassing the second stage completely. But I will let him clarify. The original Rocket did not have a bypassed cathode on the second stage.
Ahhh, thanks. The bypassed cathode was my original intention but now I'm into a 2 channel approach.
Thanks Dave (colossal),
That indeed was what I was referring to the cathode cap lift.
studiodunn
M Fowler wrote: Wed Apr 08, 2020 3:03 pm Thanks Dave (colossal),
I might actually go with this approach for a boost depending on my ability to get the "channels" volumes to be close enough to work. Bypassing the cathode is a perfect jump in dBs and grit, so I may just add that to the foot switch regardless.
On some amps to give it more options I will use a DPDT mini toggle switch (center off) and put 10uf down and 25uf up for the first cathode bypass cap.
For the 2nd bypass cap I use foot switch with 25uf/25v bypass cap.
For bright switch I like to use DPDT (center off) up 500pf and down 220-250pf. 100pf just never does much for me as brightness.
studiodunn
M Fowler wrote: Sun Apr 12, 2020 6:34 pm On some amps to give it more options I will use a DPDT mini toggle switch (center off) and put 10uf down and 25uf up for the first cathode bypass cap.
Thanks Mark.
So at this point I am looking like this:
V1a is stock 220k - 1.5/25u
V1b is wired in as my 2nd channel like the schematic I posted - 100k - 2.7/.68u. I did not use the bleed cap on the Gain pot and I ended up running a 47k from the boost input to ground to tame the overall temperament of the "boost"
V2a is 100k - 1.5/ 1u. The byapass cap is wired in as a boost that will work on either channel. I was running out of real-estate, so i expect some hand burns when unplugging the FS after power down.... :shock:
I'm still waiting on a relay for the channel switching which will go on the face.....where it says boost :roll:
studiodunn
Who doesn't love a poor quality demo? I swear i have plans to actually use a mic and demo a build some day...
Colossal
Post by Colossal »
Excellent! The clarity in clean mode is really nice. Very gainy in Boost mode too. What speaker are you using?
studiodunn
Colossal wrote: Wed Oct 21, 2020 10:56 pm Excellent! The clarity in clean mode is really nice. Very gainy in Boost mode too. What speaker are you using?
Thank you sir! Amp is loaded with a ET65 at the moment. I went through about 5 speakers before landing on the ET. The amp sounded good with them all in their own way, but it came down to a Gold Alnico and the ET65 and the gold was just a little too bright for this build. This is a really great circuit and I could easily use it and pedals to do all but high gain chug type of stuff.
Colossal
Post by Colossal »
studiodunn wrote: Wed Oct 21, 2020 11:15 pm
That's interesting about the Gold. Was it well broken in? Your demo sounds really good though. I love the clarity!
Sounds great.
I like the WGS Veteran 30 but some of my locals like the Celestion Alnico Gold.
studiodunn
M Fowler wrote: Thu Oct 22, 2020 3:03 am Sounds great.
Thank you. I really liked the Gold as well and did demo a V30, but the ET65 just had the right amount of smooth and grind to it for this build to my ear. I landed on the speaker that sounded great with the EQ at noon, but like I said, the amp sounded good with allot of options.
Post by Mark »
The boost really changes things. It’s a very different amp, the PPIMV is a good thing on these amps and AC-30’s in general.
My Rocket is a clean machine, it sounds good when driven, but I rarely turn it up so it is clipping.
Did you try the Ken Fischer mod and using a 500pF cap instead of the 50pF treble cap?
I’d want to switch between those values.
studiodunn
Mark wrote: Tue Oct 27, 2020 4:49 am The boost really changes things. It’s a very different amp, the PPIMV is a good thing on these amps and AC-30’s in general.
I believe I used the 50pf. I'll have to go back and look, but I don't think I would need anymore treble in this one.
