asteroid question
asteroid question
what brand tube sockets were used and where can you source them?
Re: asteroid question
Angela has them. Don't know if they are the exact brand used however.They are expensive.
They are the Belton variety IIRC.
http://angela.com/ninepinnovaltubesocke ... ories.aspx
Can't recall if they were top or bottom mount though.
Hopefully someone more knowledgable will chime in soon.
Dave O.
Dave O.
the only belt on ones i see are micalex and silver. the ones in the komet are white ceramic and gold
Gulp! My bad.
I missed the Asteroid and thought Express.
A thousand pardons,
Dave O.
A thousand pardons,
Dave O.
The brand is Azuma. Bottom mount ceramic gold pin.
They are $160 on ebay http://compare.ebay.com/like/3502728582 ... s&var=sbar
9 pin sockets are $5.95 at all parts http://www.parts-express.com/pe/showdet ... e=googleps
$9.95 at Angela http://angela.com/eightpintubesocketpre ... cgold.aspx
I used the silver type on mine.
Do many of you guys use the ceramic sockets in your amps?
I have read that if the amp is particularly loud and gainy the ceramic sockets can become more microphonic because of their hardness and coupling to the chassis.
I have ceramics in my personal Liverpool and can attest that it took lots of effort to stabilize microphonics etc.
Another Liverpool I built subsequently had sockets provided by RJ and they were great!!
Markus
Markus
.........Now where did I put it?
I've built Komet 60, Express and JCM800 with ceramic and haven't had problems but I prefer Belton tube sockets just using up some of my old ceramic stock is all.
Yes Mark
I have to add that there is probably a range in quality of ceramic sokets
IIRC mine were from Tube depot- should be fine but they made my V1 sing.
And also with the Beltons I sense the tubes "sit" better. With the ceramics it's as if they wiggle more easily
Make sense?
Maybe its just me
M
Make sense?
Maybe its just me
M
I've found ceramic sockets just don't hold the tube as tightly as Beltons, especially with octal sockets.
