Opinions on rocket PS filtering sought
I'm starting on a new cost-is-no-object rocket reverb project soon...for a client (my first w/verb). I was looking through my parts and I have an atom 100uf cap that I'm tempted to use in place of the standard 80uf. I wouldn't even consider this except for a great piece of luck I had recently. I bought a box of worthless tubes at an estate sale and, lo and behold, the one tube that was worth anything was a sparkling new Mullard GZ34. So, should I proceed with the robust rocket PS, or sell the mullard and put one of my kids through college?
This message has been printed using 100% recycled electrons.
Re: Opinions on rocket PS filtering sought
I suspect you will kill that Mullard. I haven't had my Rocket going long enough to comment about reliability but there is always a fingers in ears moment when turning it on.
Possibly a better idea is O'Conner's idea of using a large choke and have that before the main supply, check out the Vox section.
This Rocket is going to someone else, right?
Your call, but to my mind that is not the best situation to step beyond the published ratings.
tony
tony
Great advice, guys. Thanks. I'd really hate to kill that mullard. I recently built an asteroid that eats jj's like crazy. I'm nervous even using it in that amp. I'm currently running a copper cap.
I'm gonna see if I can find that O'connor article.
Are you talking about putting the choke before the plates? That would make it pretty stiff. I would go the opposite route and go 40 mf or lower.
Just remember that the 60uf rating for the GZ34 is a full current (volume) rating.
I found the O'connor article...he suggests a mod for a Vox AC30 in which
he recommends placing a 100uF cap AND a choke prior to the output transformer power supply node.
Shortly thereafter in the same article, he suggests a further mod...switching to a SS power supply! I will stick with the 80uf and be happy...my next project is a 200 watt Sunn-ish bass amp. 1600uf of reservoir!and a string of uf4007's .
I've experimented alot with my ac30, and ended up preferring uf4007s into -CIC/Pi filter with 32uf before choke and 32uf after choke (and 33uf at the screens)KellyBass wrote:I found the O'connor article...he suggests a mod for a Vox AC30 in which
http://ampgarage.com/forum/viewtopic.php?t=23052
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
