Trainwreck build - First amp
Hi guys!
First, I'm new to this forum. My name is JP Guerin. I'm from Quebec, Canada. So yes that's why my english is bad ! I'm a mechanical engineer but I'm in love with electronics!! I've built several pedals in the last year and I now want to build a Trainwreck Express.
I ordered my parts from RJ Guitars and I should get them by this week and start my build next week.
I'm going to post pictures through the whole process. Any tips is much appreciated.
I have some questions before I start:
1- What kind of solder are you using? I've only used flux core solder. That's cool?
2- I searched on forum for VVR Installation, pictures and guide but I didn't find what I was looking for. (Dana Hall VVR 3 must be my solution?)
3- I would like to build a 2x12 cabinet. What are your suggestion for speakers?
Special thanks to RJ for all his parts!
Thanks!
JP
Thanks!
JP
JPGraphX
Re: Trainwreck build - First amp
Is there any picture here to see how pot ground is done? I've seen tab to go through pot shaft, is it the way to go?
I don't understand the "twist tab at the end", why twist it?
Thanks,
JP
Thanks,
JP
JPGraphX
Take a look at this one I built. You don't need both tabs.
I think that image you have is showing the options available to you.
http://ampgarage.com/forum/download/file.php?id=9361
Hey thanks fishy!
By the way, nice and clean build! How does it sound? You're happy with it?
JP
JP
JPGraphX
Speaker
I have a Combo amp Hughes & Kettner Dual 6L6. When I'll have to do some test, may I use this cab? 2x12'' Eminence Rockdriver Cream 8 ohm.
How do you think it is going to sound? (this is temporary, I want also to build a cabinet with speaker)
Thanks,
Thanks,
JPGraphX
Thanks. To my ears it is great.JPGraphX wrote:Hey thanks fishy!
JP
http://ampgarage.com/forum/viewtopic.ph ... =liverpool
This thread had a few clips posted from others which are well worth a listen.
Liverpools rock!
- RJ Guitars
Hey JP, I hope this is off to a good start for you! I missed your first post when it came out. I had a bit of a distraction here last week.... which is really more a perpetual state of mind.
Did you figure out how to do your PEC pot grounds? The explanations you received were correct. you can solder to the tab ends either way.
Fishy - it's good to see you posting again. Hope things are going well down there in the land of sunshine.
rj
rj
http://www.rjguitars.net
Yes, it's either I drill and solder through the tab or I twist the tab and solder on it.
All your parts are in montreal now, I should receive them today or tomorrow!! I'm like a kid..!
JP
JP
JPGraphX
Hi!
Am I right to pretend this layout is not correct ? The pin left from the hole should be align at top row? And the one at top right of the hole should be 4 column right. (By column I mean the small holes).
Thanks,
JP
Thanks,
JP
JPGraphX
Okay, I corrected my board. What when two wires can't fit in the turrets?
JPGraphX
Rap em YoJPGraphX wrote:Okay, I corrected my board. What when two wires can't fit in the turrets?
Yes thanks!
Here is a small step.
Tips are welcome!
JP
Tips are welcome!
JP
JPGraphX
Turrets were made for wrapping; and you can add a connection above or below. Connections on the board itself are semi-foolproof as long as the solder joints are good. It's the lead dress that can get you. Continue to post as you go.
Yes I'll post step by step! You guys have experienced and I want to do it right!
Thanks and welcome on my topic!
JP
JP
JPGraphX
