Songwriter Group Build -- Not Gonna Happen
- RJ Guitars
Out of respect for Hogy and the folks at Komet, I need to withdraw the offer to help folks build one of these amps.
http://www.rjguitars.net
Re: Songwriter Group Build -- Not Gonna Happen
From what Hogy mentioned in a post about Inger, I gathered that the 'Bass Cut' switch may switch out the .0047uf (Classic AC30 'Cut') used for the 'Treble' pot for a larger cap. Not sure which value, but I did try a couple a while back.
I didn't know you were planning on going with both switches.
Edit: RJ, I'm not sure if the bright caps on your layout are correct. I could never figure out why, but I was told more than a couple times that the examination was meticulous and that's what he got. On my schem, they're 200pf and 250pf. I can't see it being much of a difference between the two and in parallel it would be, but they're clearly not wired like that in the pics we've seen.
- RJ Guitars
Post Deleted
The gutshot pic I saw the amp had a NFb. I wonder if the other switch was to turn it on or off....just speculation here. Maybe k decided they liked it in there all the time and deleted the switch on their production model
The second switch has been stated as a 'Bass Cut' by Hogy, one of the owners of Komet. NF resistor is 220k and tied to the 16R tap of the OT sec.guitarsnguns04 wrote:The gutshot pic I saw the amp had a NFb. I wonder if the other switch was to turn it on or off....just speculation here. Maybe k decided they liked it in there all the time and deleted the switch on their production model
V1 is wired in parallel with a 220k plate load resistor. Grid stoppers are each 27k. Cathodes also wired in parallel with a shared 1.5k bias resistor and a 1uf bypass cap.BLT wrote:I've also noticed split grid resistors on V1.
After some reading it looks like Blackburn is correct. The amp with the octal phase inverter had a bass cut switch and the other with 2- 12ax7's didn't have it.
- RJ Guitars
SW-30 schematic posted
Post Deleted
Hogy made this statement: If you want to experiment with the Bass Cut Switch, look at the JMI AC15 circuit and tweak from there.
RJ, yours looks mostly the same as mine. I don't have the bleeders on my schem, though. Also, reservoir capacitance on mine is a pair of 40uf. Shouldn't be anything to look too deep into. Should turn out to be a good project.
Only thing I could think of was to use the bass amplifier spec'd cap in lieu of the .0047uf. I tried a .1uf and am pretty sure that ain't it. He did say to experiment. These days, I'm mostly just curious and don't really care. FWIW, Hogy also said that Bree sounded better than Inger and that's why they based theirs on that one instead.M Fowler wrote:Hogy made this statement: If you want to experiment with the Bass Cut Switch, look at the JMI AC15 circuit and tweak from there.
RJ added the bleedersBlackburn wrote:RJ, yours looks mostly the same as mine. I don't have the bleeders on my schem
TM
- RJ Guitars
Post Deleted
RJ Guitars wrote:Yeah, I saw that and was trying not to overthink the reason as to why.Blackburn wrote: Did everybody catch that little subtle thing on the power supply? They split the rail and V1 actually runs a little higher voltage than V2. Not sure exactly what the strategy is behind that but I just followed the info I had here.
TM
- RJ Guitars
Post Deleted
