Trainwreck Liverpool build comes to Life!
I just finished a Liverpool style clone build (non standard transformers) . This amp sounds so amazing with a strat. I think anyone who plays a strat needs to here how amazing their guitar will sound with this amp!!! The high gain tones are amazing, AC/DC here I come!
I installed a Type 3 master vol that I can switch out of the circuit with a pot that has a SPST switch on the back. I used a Vox AC30 style output tranny from Weber and a Twin Reverb power tranny ( I had them in my parts bin). I installed a VVR on a terminal strip that I use to dial in the Plate voltage to 340volts ( red knob).
I used 2 different sets of matched tubes. One set are JJ's and the other set are 7189's . The 7189 tubes have more head room than the JJ's.
Need to finish a head cab now!
Pics below
Guy77
Pics below
Guy77
Re: Trainwreck Liverpool build comes to Life!
Nice work! How do you find the Type 3 master?
Thank you Colossal.
I really like this Type 3 master volume. I find that it does not really harm the tone at all. I also find that I can get the most amazing overdriven tones at lower volumes when I max the volume and minimize the master. It is so much better than any overdrive pedal!
Cheers
Guy77
Cheers
Guy77
I was making a few changes to my Liverpool clone amp last night. I changed the 2 separate 120 ohm cathode resistors to one 50 ohm cathode resistor for all 4 tubes. In both cases my bypass cap was a stock 220uf.
I noticed the change in sound right away! The best way I could describe it was that my clean tones became sweeter sounding!
In both cases I have lowered my first power supply filter cap from 80uf to 50 uf, all other caps are original spec sizes.
Cheers
Guy77
Cheers
Guy77
That's interesting on the single catthode resistor. I haven't tried that (yet).
You're right about a strat through a Liverpool - match made in heaven.
Why Aye Man
Separate 120R with a 220u on each one, and a single 50R with a 220R? For sure that will give different results.
Yes , the change I made is exactly as you described it Martin.
Cheers
Guy
Cheers
Guy
I think one cathode resistor generates more 2nd harmonics -- yeah!!!
I think that may be the case if the cathode resistors were specific to each 'push' / 'pull' side.
But if, as with the Liverpool, each cathode resistor handles a p-p pair, then I think it should work out pretty much the same as if all 4 shared the same resistor.
So the difference (between 2 x 120 and 1 x 50) may just be down to running the tubes even hotter.
- RJ Guitars
I would tend to agree that the tubes are running hotter and you'll sure hear it... I haven't run the numbers but this has to be close to the limit. Having said that I'm not sure it is as hot as Vox ran them?
http://www.rjguitars.net
