Phase inverter issue on express build
MikeR670
Post by MikeR670 »
Is there a way to trace phase inverter voltages properly? I have b+3 into phase inverter circuit at 410 vdc. Then it splits and goes through the two resistors (one 100k and one 82k as per the schematic Kelly 90s), and onto the plates of phase inverter tube. But I read 171 volts pin 1 and 368 volts pin 6. Shouldn't they be almost identical voltages?
jjman
Re: Phase inverter issue on express build
Post by jjman »
Is B3 supposed to be that high? Are the power tubes installed? Did you double check the plate resistor values with a good meter?
