Trainwreck Rocket 10 Watt or 25 Watt Bias Resistor???
TimDude
Post by TimDude »
I'm building a Trainwreck Rocket. The schematic and the layout call for a 50 Ohm 25 Watt biasing resistor. However, I noticed that Ceriatone only uses a 10 Watt resistor. In my inventory, I only have a 10 watt resistor. Is there a reason I would need the 25 Watt resistor? I'm referring to R27 on this layout from the files here on the Amp Garage.
Re: Trainwreck Rocket 10 Watt or 25 Watt Bias Resistor???
10 watts should handle the power OK. But that 25W chassis mount resistor looks so good and provides a nice mounting point for the bypass cap.
With the cathode voltage shown in the Rocket documents, it's only dissipating about 1.3W at idle. Note that if it is the same aluminum cased type shown in the layout, it has to be attached to a heat sink (the chassis, e.g.) to achieve its full rating.
TimDude
Post by TimDude »
martin manning wrote: Mon Jul 20, 2020 4:09 pm With the cathode voltage shown in the Rocket documents, it's only dissipating about 1.3W at idle. Note that if it is the same aluminum cased type shown in the layout, it has to be attached to a heat sink (the chassis, e.g.) to achieve its full rating.
Thanks! What is the best way to attach it to the chassis? Super glue? Hot glue gun? Something else?
It should be bolted to the chassis.
TimDude
Post by TimDude »
sluckey wrote: Mon Jul 20, 2020 4:03 pm 10 watts should handle the power OK. But that 25W chassis mount resistor looks so good and provides a nice mounting point for the bypass cap.
Thanks, I agree, it looks awesome! Reading your post prompted me to ordered one, I couldn't resist. Hahaha! I'll start with the 10W for now, and I'll upgrade to the 25W when it arrives.
TimDude
Post by TimDude »
martin manning wrote: Mon Jul 20, 2020 4:15 pm It should be bolted to the chassis.
"DUUHHHH" Hahaha, thanks! That should have been super obvious to me.
Koolaide
Post by Koolaide »
Just a quick question? Should thermal transfer paste be used?
no
Post by Mark »
Thermal paste is normally used in these sorts of applications where there is a lot of heat. It is messy stuff though.
