I was looking at the Liverpool documents after watching Pete Thorn's video. The TW Liverpool docs on this site list a PT that has a 234 VAC secondary output. I have a Classictone TW-style dual secondary PT that has a 260 VAC output option as shown here:
https://s3.amazonaws.com/tubedepot-com- ... -18065.pdf
I can use a Brown Box attenuator to drop the AC down 10% and get there, but what's the best way to drop it inside the amplifier? On the B+ line before the first filter cap with zener diodes? On the secondary pre-rectifier? Between the first and second filter cap nodes? I've seen different recommendations, I'm wondering what you all think is best. Thanks.
Liverpool B+
Liverpool B+
Just plug it in, man.
- Colossal
Re: Liverpool B+
Use the 260VAC (unloaded) tap. Your rectified B+ should be 330VDC.ViperDoc wrote: ↑Thu Sep 02, 2021 11:57 pm I was looking at the Liverpool documents after watching Pete Thorn's video. The TW Liverpool docs on this site list a PT that has a 234 VAC secondary output. I have a Classictone TW-style dual secondary PT that has a 260 VAC output option as shown here:
