So i recently got a great deal on a Matchless Phoenix in Europe. I did not expect it, but the amp is very unique sounding - it sounds like the idealized rock tone in my head. It has a very smooth, but still detailed overdrive tone, nice compression, but still very well controlled on any pickup/guitar i throw at it. Sounds great on leads, rhythm and takes pedals beautifully. What stoked me the most is that smoothness. I don't understand where it comes from. It has only 3x 12ax7 tubes just as in a Top Boost style preamp and it has a dual EL34 output Stage that is supposed to be like that of the Chieftain. Is it somehow filtered in the output stage maybe?
It is such an addictive sound. None of my other 10+ vintage style amps sound like it.
So now i am wondering, if the Rockster has similar smooth and still touch sensitive qualities?
Matchless Phoenix arrived - how close is it to the Rockster?
Re: Matchless Phoenix arrived - how close is it to the Rockster?
schematic?
Chris
Love, peace & loudness!
here are some pictures of the amp:
https://reverb.com/item/4429731-matchle ... 35-chassis
Chris
It is supposedly a DC-30 preamp combined with a Chieftain Power-Amp (this has been posted on a few amp forums by posters with good reputation). I've never found a schematic of the Phoenix. Maybe i will open it up and confirm this at some point. But i do assume that is pretty much what it is - DC30 + Chieftain.
Also i noticed the amp takes even a 16db boost in the front really well, when EQ'd right - it can sound as an amp with an overdrive in front of it, when boosted. It does not fall apart as most do with such a high boost. I assume that might be because the preamp does not hit the power tubes too hard and that gives the boost some nice headroom in the power amp, while gaining up the preamp.
Yep, I saw also some comments about small differences in the voicing. Most Matchless 2xEL34s amps run above 400 Volts and the DC30s around 350 Volts.VintageCharlie wrote: ↑Tue Mar 29, 2022 8:19 amIt is supposedly a DC-30 preamp combined with a Chieftain Power-Amp (this has been posted on a few amp forums by posters with good reputation). I've never found a schematic of the Phoenix. Maybe i will open it up and confirm this at some point. But i do assume that is pretty much what it is - DC30 + Chieftain.
If it's your amp: open it and reverse engineer it.
The reverb-link shows the inside.
Chris
