Liverpool bass reduction?
Ledvedder5150
Re: Liverpool bass reduction?
Post by Ledvedder5150 »
Littlewyan wrote: Tue Feb 07, 2023 9:07 am How about this clip? Does your Liverpool sound similar to this? (Bear in mind I think he might be using a G12H cab here)
https://youtu.be/3aP4yFdejSo?t=276
This is mine through a Suhr Greenback IR,
https://on.soundcloud.com/n3EfJ
Reeltarded
Post by Reeltarded »
I like it ok!
(dc offset comment removed due to obsessive compulsive issue)
Ledvedder5150
Reeltarded wrote: Tue Feb 07, 2023 1:53 pm I like it ok!
DC offset?
Reeltarded
No, thanks! :lol:
omg it's not relevant. Umm see the (-) phase of your waveforms. 0 is not the middle. There is about 30% (+) DC offset in your recordings.
Yeah. I am never happy. You should see what happens when someone tweets about physics or a Youtube channel talks about vintage instruments. :lol:
Ledvedder5150
Reeltarded wrote: Tue Feb 07, 2023 3:19 pm :?
No, thanks! :lol:
Oh yeah, I see what you mean. Maybe that's just a Soundcloud thing. That's not how the waveform shows in my DAW.
Reeltarded
oh no now im triggered i need to go through my soundcloud and delete anything with added offset
Crisis averted. It's something they did to the visual representation only. Idiots.
Littlewyan
Post by Littlewyan »
Ledvedder5150 wrote: Tue Feb 07, 2023 1:44 pm
Sounded good. It is different to other clips though I see what you mean. Unfortunately I've never heard an actual Liverpool in person so I can only go off of clips! I've got an Express clone myself.
What settings and guitar did you use?
Ledvedder5150
Littlewyan wrote: Tue Feb 07, 2023 9:04 pm
Guitar is a Suhr Pete Thorn Signature. Amp settings were volume noon, treble and mid 2:00, bass 10:00, presence noon. 100pF bright cap. At one point I switch the the 500pF bright cap.
Littlewyan
What values did you use for the tonestack? Have you checked your wiring? Do the controls all work how they should? Same for the presence.
Ledvedder5150
Littlewyan wrote: Wed Feb 08, 2023 3:25 pm What values did you use for the tonestack? Have you checked your wiring? Do the controls all work how they should? Same for the presence.
47pF treble, 22nF mid and bass. 100nF presence. Yep, they all seem to work as they should.
Littlewyan
What are your pot values and what tapers?
Ledvedder5150
Littlewyan wrote: Wed Feb 08, 2023 6:30 pm What are your pot values and what tapers?
Volume and treble are A1M, middle is B25K, bass is A250K.
Littlewyan
I think the Bass pot is meant to be a Linear taper 250K. I'm a bit concerned that there could be something else wrong here, as with a 250K Log Taper bass pot and an already big low end cut with 2.2nF and 68K you should have a very lean amp right now. I actually thought it sounded a tad trebley in the clip you posted, maybe because so much bass is being cut. What cab do you normally play through?
Ledvedder5150
Littlewyan wrote: Wed Feb 08, 2023 9:36 pm I think the Bass pot is meant to be a Linear taper 250K. I'm a bit concerned that there could be something else wrong here, as with a 250K Log Taper bass pot and an already big low end cut with 2.2nF and 68K you should have a very lean amp right now. I actually thought it sounded a tad trebley in the clip you posted, maybe because so much bass is being cut. What cab do you normally play through?
2 different cabs. A Suhr 212 closed back with Greenbacks. And another 212 semi open back with a V30/G12H-30 combination.
Littlewyan
What if you clip another 2.2nF in parallel with the existing 2.2nF between the 2nd and 3rd stages? Interested to see if you get closer to Pete's sound or if you feel the bass situation becomes much worse.
