Liverpool preamp tube differences
Ledvedder5150
Post by Ledvedder5150 »
Tonight, I thought I'd try rolling some tubes in v1 of my Liverpool. I noticed some very dramatic differences between different tubes. Much more than I've ever noticed in any of my other amps. So, for curiosity sake, I thought I'd take some oscilloscope measurements. I've never done this before, and I found the results very interesting. I ran a 150mv sine wave into the input, all amp knobs at noon, measuring after the 2n2 coupling cap, right before v2b.
RFT - 3.5V
Mullard - 4.5V
EHX - 1.2V
Genalex - 3.2V
I never realized how much different each tube's gain could be. And I've never noticed how dramatically different they can affect the tone in any other amp before this one.
So I'm curious... What is everyone's preference of tubes in a Liverpool? Or an Express?
dblgun
Re: Liverpool preamp tube differences
Post by dblgun »
I like the Sylvania 12AX7WA in both Express and Liverpools. I also have had good luck with Amperex,Mullard and Tungsram in the Express, I haven’t tried any of the newer made tubes in either.
bepone
Post by bepone »
can we see pictures of all those tubes? are they all 12AX7? EHX has always the highest gain, so probably is almost dead..
expected voltage gain is 50 so, measured voltage must be around 4.50VAC, all what is less indicating worn tube
Ledvedder5150
bepone wrote: Wed Feb 08, 2023 9:50 am can we see pictures of all those tubes? are they all 12AX7? EHX has always the highest gain, so probably is almost dead..
I'll try to get some pictures of them today.
Ledvedder5150
Ok, here are the tubes from left to right. RFT, EHX, Genalex, Sylvania, Mullard.
Ledvedder5150
And here are the readings I'm getting at the spot noted.
RFT
EHX
Genalex
Sylvania
Mullard
bepone
Post by bepone »
first, EX tube is 12AY7, it is lower gain tube , so it is normal.
other are here somewhere
Ledvedder5150
bepone wrote: Wed Feb 08, 2023 2:40 pm first, EX tube is 12AY7, it is lower gain tube , so it is normal.
Oh you're right! Why was I thinking it was a 12ax7? :roll:
