test pictures
test pictures
[/img]
Here are the 3 different Output's I have (Left) 4200 (ac30) output/heyboer
(middle) 5200Heyboer, Right 6600 Heyboer all 30-35 watts.
Ley me know if this works!!!!
Chris
Chris
Re: test pictures
[/img]
Here's my liverpool clone
Re: test pictures
[/img]
The cab it's going in.
Re: test pictures
[/img]
liverpool back
liverpool back
Lovely work Chris!
Dear Chris
The Liverpool amp looks great!
One question though, what is the measurement of the lamination on the front of the amp?
I thought the lamination was the same size and the height of the chassis. Of course I could be wrong.
Mark Abbott.
Mark Abbott.
Re: test pictures
Chris
That looks awesome!!!
How about some internal shots?
Any clips?
Did you build it using the schematics in the Files section?
Omar
Any clips?
Omar
Tone by misadventure
Re: Lovely work Chris!
Hi Mark,Mark wrote:Dear Chris
Mark Abbott.
Thank-you!!!!! the measurements are 2-3/4" x 19",I don't know if this is exact as my cabs are slightly larger than a standard wreck, I think.......If you look at some of the photo's on-line it appears from the back that the front face slides into a track on the front panel ,making the face plate bigger than the chassis,anyway the cabs were built about 2 years ago.......long before you and Matt T. did all the leg work on the great info we now have!!!!!
Thank-you Mark!!!!
Chris
Re: test pictures
Thank-you Omar!!!!!!!Omar wrote:Chris
Any clips?
Omar
I do have an internal shot to post will try later to up-load
No clips of either amp at the moment
All the work ,with the exception of the cab and face plate was done with info gathered by Mark Abbott and Matt Taylor... All contained here on our site!!!!!!
Thank-you!!!!
Chris
Re: test pictures
Omar wrote:Chris
Any clips?
Omar
HI Omar,
Heres a shot of the inside!!!
Chris
Re: test pictures
That looks great~!! One question: how did you join the corners?? Did you just use a 45 and glue or did you biscuit join or ??
Thanks a lot~!! Good job~!!!
Mike
Mike
Re: test pictures
HI Mike,Mike wrote:That looks great~!! One question: how did you join the corners?? Did you just use a 45 and glue or did you biscuit join or ??
Mike
Thank-you !!!! The cabs were biscuited.
Chris
