Q - Rocket Board Size?
Dumb question of the day:
what are the rocket's board dimensions? I've looked at Tim's layout but am not sure the drawing is meant to be to scale or what the perf spacing is. I get about 2.5 by 11 inches which seems too long.
Thanks in advance
Thanks in advance
Re: Q - Rocket Board Size?
Not sure I can answer definitively here but this is what I used
The board is based on the rocket build Allyn posted. I worked on a spacing of .225" I'm not sure if it is spot on but it looks to line up well.
The PDF has the dimensions and markings for the holes. I just printed it out and stuck it to the board to drill it.
If your considering the old style perf I'm inlcined to think its very similar to the Express and Liverpool dimensions but that is a guess.
Hope that helps.
Hope that helps.
I'm sure my Rocket board was the same size as my Express and Liverpool.
2 1/4 x 10 1/4
2 1/4 x 10 1/4
Hey Thanks! Exactly what I need and more!
Mine are 8 7/8" x 2 1/4"
Dave
Dave
Instructions...I don't need no stinkin instructions
Well then my Rocket board is 8 7/8" x 2 1/4" because I got mine from Joebob but he didn't answer fast enough. So you got my 2 cents worth.
Joebod no wonder I had so much real estate in Rocket chassis.
Well your 2c is most welcome. The good news is I ordered enough board material so will just need to cut DOWN a little.M Fowler wrote:Well then my Rocket board is 8 7/8" x 2 1/4" because I got mine from Joebob but he didn't answer fast enough. So you got my 2 cents worth.
Nick,
Have you heard or played through a Rocket? Because the Rocket has moved into my favorite amp slot immediately after I finished building it with no tweaks or tube changes to date. I think the Rocket is the best of the TW line-up.
Also, right after I get done with my 80w express build I will be sourcing parts for a 60w rocket project.
To M Fowler,
So how does the 3 differnet Rockets sound? I am curious if the one with Sozo's has a better sound than the other 2 you have.
Dave
And thanks again, Mark. I have on occaision changed my boards from one run to another to accomodate bigger components that i buy (like SOZO).
Dave
Dave,
I bought one Liverpool board from you with 150's. One Express with Sozo for my combo amp and one Rocket with 150's. At least I thought those yellow caps are 150 mallory?
I only have the one Rocket so far. I am building an Express and trying to get as close in looks and performance to the original so I will be going with vector style boards on that project.
I am going to go with the 60w Rocket to see how that sounds compared to the 245-0-245 Edcor PT and Dynaco A470-S OT Rocket I built.
Hey Mark,M Fowler wrote:Nick,
I've played an AC30 for the last... well... 35 years!! I'm hoping the Rocket will sound at least as good as that (but without the noise and hummmm and 85lb lug!!)
Might have to build a second one though because I only have Allyn's Express chassis - my first attempt will be with KT66's.
I've already built a Lightning clone (somewhat disappointing tonally but quiet as a mouse) Probably need some RTF (RFT?) EL84's I guess...
cheers
Nick
Your going to like the Rocket then Nick.
The lightning is a great amp I built the spitfire instead of the lightning.
So your going to built the Rocket KT66? That will be good project and I believe some of the guys here like the sound of the ones they built.
