Hiwatt Chassis...
Vox and Hiwatt Discussion
playonit
Hiwatt Chassis...
Post by playonit »
I would like to build a Hiwatt 504 circuit... Does anyone know of a source for a punched chassis? I would rather buy one then punch my own on this build..
I brake for Lard......
Re: Hiwatt Chassis...
VHR stopped selling chassis
Ceriatone.com
Weber Hiwatt kit no separate chassis available
Parts http://shop.hi-tone-amps.com/Vintage-HT ... ons_c4.htm
Not sure if Allynmey still has any chassis left.
playonit
Post by playonit »
Thanks for That....... I sent VHR an email a few days ago and had not received a response as of yet.. I will probably go with Ceriatone.. I am trying to avoid the higher shipping cost... I might still punch my own.. The only thing holding me back was needing a greenlee punch for the cap can hole size.. So I might turn the ceriatone shipping cost into a new punch purchase..
I punch the can cap holes the same size as the octal tube socket holes but I do have larger Greeenlee punches. Watch those punches because they are sized for conduit OD size and have nothing to do with actual size. Example 3/4" is larger then 3/4" so you end up with too large a hole to put a 3/4" noval tube socket in.
I use industrial metric punches for tube sockets and cap holes.
playonit
Post by playonit »
Thanks Mark..... I use carbide hole saws for the noval and octal holes... I am glad you mentioned that about the Greenlee punches.I was not aware of that.. I am trying to get away from using the hole saws.. while they do a nice job it's not a super looking job.. What are these Industrial metric punches you speak of? What is the process where do you purchase?
Thanks Greg
dartanion
Post by dartanion »
One big note with the Ceriatone chassis, it is not the same spec as a real Hiwatt chassis, it's a bit smaller. Thus, faceplates and cab would need to be Ceriatone sized/spec.
Eardrums!!! We don't need no stinkin' eardrums!
Well there just punches but I ordered from industrial suppliers by googling.
See photo L to R 18.6mm for Belton noval, 22mm for ceramic novals, 30mm for Belton octal and Greenlee set for everything else.
playonit
Post by playonit »
Thanks Mark..... I will look into them..
JoeCon
Post by JoeCon »
What Mark is really saying is watch out for "conduit" sized punches as they are oversized. But Greenlee does make actual sized punches as well where the 3/4 inch really punches a 3/4 hole. I have 3 of those and they work great. Just punched two chassis with those.
Also ask Mark about DDwag chassis if you're gonna punch your own. Nice work and the price is right...
HTH
playonit
Post by playonit »
JoeCon wrote:What Mark is really saying is watch out for "conduit" sized punches as they are oversized. But Greenlee does make actual sized punches as well where the 3/4 inch really punches a 3/4 hole. I have 3 of those and they work great. Just punched two chassis with those.
HTH
Thanks For the info..... have been using Ddawg chassis... your right great stuff at a good price....
Yup I have a stack of Ddawg chassis waiting to be made into amps.
I used a 17x8x2 chassis with a rack faceplate for my Dumblelator.
Ddawg will make to any size you want for custom applications.
Allynmey
Site Admin
Post by Allynmey »
I still have some prepunched ready to build steel chassis from my last run.
$79.00 shipped in the US
This what Allyn's nice chassis look like with Allyn's faceplate and back plate.
playonit
Post by playonit »
Allynmey wrote:I still have some prepunched ready to build steel chassis from my last run.
Do you have the Faceplate also?
I'll take one... should I pm you?
Allynmey
Site Admin
Post by Allynmey »
Faceplates are available from BNP Lasers
:wink:
