Muchless Spit Build
Vox and Hiwatt Discussion
fusionbear
Muchless Spit Build
Post by fusionbear »
This is a fun one I just started today. Hope to finish by the end of the week.
[img:3264:2448]http://i.imgur.com/CbndxNf.jpg[/img]
[img:3264:2448]http://i.imgur.com/crfzHbN.jpg[/img]
[img:3264:2448]http://i.imgur.com/5jHUUQh.jpg[/img]
[img:3264:2448]http://i.imgur.com/VtJvTZV.jpg[/img]
Learning to learn...
Re: Muchless Spit Build
The Matchless Spitfire is a good circuit and I used one for gigging for several years. To cut through the mix I simply relied on my pedal board effects to help me through.
The fat switch doesn't have much apparent effect.
Have fun.
Nice!
Very tidy Merlin style heater wiring.
What chassis is it (I assume you haven't done those cut outs for the transformers)?
jelle
Post by jelle »
Nice!! :D
Jelle
fusionbear
Amp is done and it came out really well:
[img:3264:2448]http://i.imgur.com/NLLvlTH.jpg[/img]
[img:3264:2448]http://i.imgur.com/aCG64xJ.jpg[/img]
[img:3264:2448]http://i.imgur.com/xXxNEx6.jpg[/img]
https://www.youtube.com/watch?v=WVKYCdigKkc
joeboo88
Post by joeboo88 »
fusionbear: nice job and it sounds awesome!
from your pictures on your version of the PPMIV I don't see the usual 2M
resistors across the lugs, how did you wire that up?
I see lug 1 to ground and ??
I want to build a Spitfire and maybe add an EF86 channel
and employ your MV
I also listening to your 1986 Plexi Build video....Wow
thanks in advance, Joe
fusionbear
joeboo88 wrote:fusionbear: nice job and it sounds awesome!
and employ your MV
One lug goes to ground and the other goes to the input of the power tubes. There is always a 250k reference to ground for the screens. No need to use extra resistors. The wiper is the input.
