Sapele pedal board build
A friend talked me out of my lattice style oak board and I needed another. I had some sapele [sorta mahogany with some figure] laying around and I had the 'Go build something, you fool!' urge so I obeyed.
It's 21x14x3.5". I put the power supply and all guitar / amp cable connections underneath. I like the clean look and the 'I can't kick / step / break plugs and connectors' security.
I used a tea wash and first slurry sand with 320. More sanding tonight with 400 and then oil out.
Re: Sapele pedal board build
Beautiful, Russ
The size of that thing makes me wonder how many pedals you have
- JazzGuitarGimp
I wasn't going to be the first one to say it!Ken Moon wrote:The size of that thing makes me wonder how many pedals you have
Lou Rossi Designs
and Schematic Capture
Are you implying something?
This is the 5th board to date. The first three were misguided attempts at building a compact and lightweight boards. Those failed as I couldn't arraign the pedals that kept appearing to fit. That's right they just kept showing up! Magic I guess.
The other problem was they weighed more than the lattice style builds. Also - have you seen the size of pedals recently? What are the designers thinking?!? What are they feeding them?
The last one was 20x14 and it worked well but I had issues with crowding. The new one is the pedal board version of punching another hole in my belt to ease the strain.
If anyone even mentions P.A. [Pedalholics Anonymous] I'll be forced to unleash my 'Punch your nose through the screen' emoticon to chastise the judgmental ones.
Wow. Too pretty to step on. "Please remove shoes before operating. And get a pedicure, you filthy musician."
Beautiful work Russ. I wouldn't want to get a booted foot near that thing. It looks like fine heirloom furniture.
(looks like xtian and I were thinking the same thing)
- dorrisant
Ha ha ha ha!!!!xtian wrote:Wow. Too pretty to step on. "Please remove shoes before operating. And get a pedicure, you filthy musician."
Beautiful work though!
Please submit a pic when it's all wired up.
How are the pedals secured to the board...velcro?
+1 on that.xtian wrote:Wow. Too pretty to step on.
- norburybrook
WOW!!! Really beautiful.....
But, as mentioned above , how are you attaching pedals? You can't put Velcro on that!!
Marcus
Marcus
Initially I plan to use flexible banding around the plugs. The long term is to figure out a non invasive attachment for a threaded rod to attach to the bottom of the pedal and thread though a cross piece underneath the slats. This would allow for easy positioning and swaps.
Alternatively I could do the brute force technique and drill and tap the bottom of the pedals and use a screw/threaded rod though a cross piece underneath the slats.
Every time I mention this method the pedal police wail about desecration and devaluation of something that is a tool. Much like the 'no velcro has ever been on this pedal' sales pitch.
Finished - for now. Had a hiatus when I dropped the damned thing and broke the front corners off. Titebond to the rescue.
Box wired up
I tapped a .5" x 1.5" brass plate [8-32] attached to the bottom of the pedals with double sided tape and then a 1" washer / lock washer / nut
The power supply is zipped in for now - I used wood wedges to hold the last one in place.
Sadly I only had enough brass for 6 pedals - note to self: If you think it will work buy at least two!
Off to the hardware store for more brass.
I have a RAT 2 inbound and am trying to talk myself in to a Strymon DIG. Maybe if I'm a good boy Santa will bring me one. DISCLAIMER - I set the good boy bar very low.
Box wired up
Wow!
After looking at your nice woody, I feel that I've been short-changed, and I'm starting to question my adequacy
[img:816:612]http://i514.photobucket.com/albums/t346 ... 141233.jpg[/img]
Wow!
That's impressive!!!
Kind of at a loss for words...
Very nicely done!
Very nicely done!
It sounded so sweet... And then it caught fire!
