Flaming Maple
Decko
Flaming Maple
Post by Decko »
Well here is my first crack at wood working. Flamed maple miter cuts using biscuits. 3 coats of clear.
I quickly learned that you should use the best paint brush money can buy. The coats lay down nicely and less bubbles.
This amp is the "Beluga" series. 10 watt express.
Beluga is a little whale. My daughter sings a song called baby Beluga.
Decko :)
Dr-Joned
Re: Flaming Maple
Post by Dr-Joned »
First Crack??
Man that looks might nice for a first attempt. You ought to be proud!!
I Think I Think Too Much !
sepulchre
Re: Flaming Maple
Post by sepulchre »
That's some beautiful wood. Excellent job - surely doesn't look like a first try.
Decko
Post by Decko »
Thanks...I took my time with it and made sure that I did not skimp or cut corners. The wood was pricey, so it had to be done to perfection.
For example, I spent hours with the 5 pieces of raw wood examining the grain patterns. Then determined the best fit for visual appearance.
Cheers
Decko
Raw
Raw
First coat
First coat
Formation
Formation
Re: Flaming Maple
Great job.
What 10 watt express? Where?
Also: Raffi. Been down that rabbit hole.
Decko
Raffi
Post by Decko »
Xtian
The amp is laid out mechanically as a TW express. However the power board and trannys were reconfigured for to accept dual 6SN7GTB's. the reason I say ten watt is that the OT is rated for 10 watts. May be an incorrect usage of the overall rating but sounds good!
I've sold 6 of these units. My guitar buddies like em. Easier on the ears, the kids and the neighbors and of course the wife!
Of course I never intended to sell them as each amp built was designed and configured for me.
Decko
steve_p
Re: Flaming Maple
Post by steve_p »
That looks great!
What do you have for a biscuit cutter?
I want to build an express cab, but I am not sure I want to attempt the interlocking dado cuts for my 1st try.
Also, how did you attach your valance, cleats or a dado cut?
Thanks,
Steve
amplifiednation
Re: Flaming Maple
Post by amplifiednation »
That looks great! Nice job on the flame! Is that just an oil or did you die it? Looks killer
Amplified Nation
www.amplifiednation.com
@ampnation
Decko
Cuts and finish
Post by Decko »
Steve, I bought a biscuit cutter then went to home depo and picked up the biscuits. I had cut 45s on the pieces then used the biscuit cutter to make the inserts. Easy.
As far as the finish I used a clear polyurethane. No dyes.
Decko
amplifiednation
Re: Cuts and finish
Decko wrote:Steve, I bought a biscuit cutter then went to home depo and picked up the biscuits. I had cut 45s on the pieces then used the biscuit cutter to make the inserts. Easy.
Decko
I didn't know maple would pop so nicely with poly! That must be a really nice piece of wood.
Amplified Nation
@ampnation
surfsup
Re: Flaming Maple
Post by surfsup »
Decko beautiful. Just beautiful. You should be extra proud especially if this is first try!
Wallbanger
Re: Flaming Maple
Post by Wallbanger »
Super nice work!! Fyi here in North Ga. I can buy flamed maple for 1.86$ a board foot, needs to be finish planed and ripped to size but still, thats cheaper than pine shelf board from Home Depot. I have to go through piles of it to get nice flame but they always have it. Suwanee lumber in suwanee ga. Is the place, little local lumberyard. We just had some big storms, I'm gonna go picking thru the pile of new lumber when I get home. Here's some I have conditioning
Pete
