Does anyone have the dimensions and other details of a Marshall "Silver Jubilee" 2556A & 2556B 2-12 cabs?
I have done a few search and so far NO luck what so ever, nothing other than a few "pictures" but that does not help me. I understand it's small than the 4-12s they make BUT not much, but I need the actual measurements IF at all possible.
Thanks!
Marshall 2556A & 2556B dimensions?
Re: Marshall 2556A & 2556B dimensions?
I'm guessing the dimensions are 34C/26/32
Nice messurements. 😀
That's the cab! So do you know the messurements of the CAB? 😉
Cabs are for sale on eBay. You might get lucky if you send a question to a seller. I suggest that it isn't necessary to say why you want the info. Let the seller keep the impression that the info will encourage bidding.
I believe there is a Marshall forum somewhere. You might get someone there to measure his cab(s). Again, I wouldn't be too forthcoming about cloning one as that might be considered heresy and depress your chances of getting what you want.
I don't think the girl in the picture has a tape measure.
Mojotone's version is slightly wider Width 26", Height 27", Depth 14" at base, Depth 11" top.
Research says the Marshall is 24" height by 24" wide.
http://boston.listlux.com/a,55,1500578, ... field-.htm
Thanks guys!
