Page 1 of 1
how do EVM12Ls sound in a Marshall style 1960 cabinet?
Posted: Sun Dec 13, 2015 4:38 am
by ampexplorer
are the EVs too heavy for the baffle
Re: how do EVM12Ls sound in a Marshall style 1960 cabinet?
Posted: Tue Dec 15, 2015 12:31 am
by jaysg
Both Eric Clapton and Mark Knopfler used two EV12-Ls in Marshall 1960A cabinets in the late 80's/early 90's. I believe they ran them closed back with two holes open. There should be ample videos on youtube from that era.
Posted: Tue Dec 15, 2015 12:36 am
by Colossal
jaysg wrote:Both Eric Clapton and Mark Knopfler used two EV12-Ls in Marshall 1960A cabinets in the late 80's/early 90's. I believe they ran them closed back with two holes open. There should be ample videos on youtube from that era.
Detuned!
Posted: Tue Dec 15, 2015 1:32 am
by ampexplorer
interesting idea will look for the videos
Posted: Mon Dec 21, 2015 12:53 am
by JMFahey
Never heard about that, are you sure?
Sounds gross to me, they would at least have covered the empty holes.
Using an open back cab is something and has merit on its own but closed back and 2 empty 12" holes is horrible.
Posted: Mon Dec 21, 2015 11:07 am
by pdf64
I think the 'detuned' idea is presented in KOC's speaker design book.
Some info about it seems to have gone from his site, but this page puts it in a nutshell
http://www.syer.net/detuned_cab.htm
I remember that one of my buddies inadvertently did this to his 4x12 decades ago, when he used it with a couple of the speakers removed; I expected it to sound bad but the opposite was true.
HEAVY
Posted: Mon Jan 04, 2016 2:09 pm
by zoolion
EVM 12L's weigh 19lbs each! If your only using two, I guess it all evens out but I had a Marshall 2x12 that I loved the sound of with EV's. I had two 1x12's made so that i could lift the buggers.
Posted: Tue Jan 05, 2016 1:09 am
by jaysg
JMFahey wrote:Never heard about that, are you sure.
No, however, I know that he ran the Music Man cabs with JBLs and open backs in the 70's and 80's. One way or the other, something was open. It makes sense to me to port to the front.
Posted: Tue Jan 05, 2016 9:06 am
by JMFahey
Sorry, not to me.
In an open back cabinet out of phase backwave must travel from speaker edge to one side, then to the back, then same distance along the external side until it meets destructively the front wave.
2 to 3 feet.
While an empty large hole (with that size I wouldn't call it a "port" any more) allows back/front shorting only 2 to 4 *inches* away
Re: HEAVY
Posted: Thu Feb 04, 2016 11:57 pm
by Mr. dB
zoolion wrote:EVM 12L's weigh 19lbs each! If your only using two, I guess it all evens out but I had a Marshall 2x12 that I loved the sound of with EV's. I had two 1x12's made so that i could lift the buggers.
Four of them in one box sounds like a trip to the chiropractor.
Re: HEAVY
Posted: Fri Feb 05, 2016 10:25 am
by norburybrook
Mr. dB wrote:zoolion wrote:EVM 12L's weigh 19lbs each! If your only using two, I guess it all evens out but I had a Marshall 2x12 that I loved the sound of with EV's. I had two 1x12's made so that i could lift the buggers.
En route to the audiologist for hearing aids..........
M
Posted: Sat Feb 06, 2016 12:52 pm
by MARK1
You could check Gary Moore with his legendary tone he menaged to pull from his Marshall JTM45 Reissue, first used on Still Got the Blues album with Marshall 1960B 4 x12″ cabinets fitted with Electrovoice 12M speakers instead of the usual Celestions
Posted: Sat Feb 06, 2016 7:28 pm
by MARK1
Oh, and Joe Bonamassa uses them too in oversized split cabinets
Posted: Tue Aug 16, 2016 1:29 am
by Paul86
And don't forget Zakk Wylde.
He only uses EV's in his 4x12's. And his are even heavier than the normal type of EV's.
TL806Q
Posted: Wed Sep 07, 2016 3:20 am
by Smitty
TL806Q Google it
