remove wizzer
Re: remove wizzer
You *can* cut it with steady hand and a very sharp box cutter but if blade sticks way too much on the far side you might cut the cone at the worst place: near the voice coil so way safer is a pair of those curved scissors often used to cut baby boy nails:
[img:300:300]http://www.2bcr8v.com/images/curved%20nail.jpg[/img]
Don´t cut them too tight, leaving a 1 or 2 mm wide ring all around won´t be heard and is safer.
Design/Make/Service Musical stuff in Buenos Aires, Argentina, since 1969
Re: remove wizzer
Removing the whizzer, also called curcumcision.
- dorrisant
Re: remove wizzer
That was good!xtian wrote:Removing the whizzer, also called curcumcision.
