How much of a gap between chassis and cab for tolex?
JazzGuitarGimp
Post by JazzGuitarGimp »
Hi All,
I am working on a build for a friend, and this will be the first build that I will also make the cabinet. I am going to deliver the amp bare - no tolex. The amp chassis is 19" wide. My question is: How wide should I make the cabinet from inside to inside walls, so that there is the right amount of space left for later adding tolex and glue on each side?
Many thanks,
Lou
Lou Rossi Designs
and Schematic Capture
dorrisant
Re: How much of a gap between chassis and cab for tolex?
Post by dorrisant »
I try to leave 1/8".
JazzGuitarGimp
dorrisant wrote: Fri Mar 10, 2017 8:22 pm I try to leave 1/8".
Thank you.... that's 1/8" total, not 1/8" per side, correct?
Lou Rossi Designs
dorrisant
Post by dorrisant »
Yes, 1/8" total... 1/16" per side.
I have run out of wiggle room with only 1/16 per side.
JazzGuitarGimp
xtian wrote: Sun Mar 12, 2017 5:16 pm I have run out of wiggle room with only 1/16 per side.
I've never worked with tolex. Maybe 3/32 per side is enough to get the chassis in and out comfortably without people pointing and gasping "Oh! Em! Gee! Look at that...... gap!" ?
Lou Rossi Designs
