After a bit of experimenting with class D power amps I decided to refurbish an old half built EV Thiele cab I had lying around to go with my kemper.
I stripped it of it's old tolex, fixed the large hole in the bottom where a PA stand top hat had been installed, made a new back panel as it was missing and set to re telexing it with green Carbon Fibre tolex.
Here's the result, a matching cab for my Kemper. It now houses a Peavey 100w black widow I had from my donor combo I'd bought recently.
I'm still learning about the whole telexing business.....it's a skill that requires time and you get better each time.
Marcus
speaker for my Kemper
- norburybrook
Re: speaker for my Kemper
Looks nice, I haven't tried any of the newer tolex yet.
Looks great! How does it sound?
- JazzGuitarGimp
Hi Marcus,
That looks great! The Kemper does not have a power amp built-in, correct? Now that I am doing a bit more woodworking, I am toying with the idea of making a pair of 1x12 cabs to use with the Roland GR-55 floorboard modeler. I know you can get class-D amp boards and power supplies on eBay for cheap, and I am thinking it would be cool to put a 100W @ 8-ohms amp inside each cab to make them "powered guitar cabs" that would cable directly to the GR-55 (well, through a stereo volume pedal...). No muss, no fuss.....
Lou
Lou
Lou Rossi Designs
and Schematic Capture
- norburybrook
Lou,
My particular Kemper doesn't have a power amp although they do do a powered version with a 500w class D mono amp.
I ve been using an 100w x2 eBay class D amp with the Kemper and its ok at reasonable volumes.
Make your cabs and give it a go ,it's all good fun
Marcus
Marcus
