Tolex glue
TUBEDUDE
Tolex glue
Post by TUBEDUDE »
What is your go to adhesive for Tolex? I've tried rubber cements, with smal results, Super77, the Tolex lifts with time. 3M has another product but it has too short an open time for me. Any of the waterborne adhesives useable? Thanx for sharing your experience.
jasonwhitecountry
Re: Tolex glue
Post by jasonwhitecountry »
Vinyl floor adhesive. It's a latex glue, water cleanup, no fumes. And cheap, available from Lowe's-type stores.
Sent from my XT1585 using Tapatalk
Re: Tolex glue
I use the water based stuff from tubesandmore.com. In the early days I put it on too lightly, and some edges lifted. Needs a good heavy coat on both surfaces, allowed to dry until tacky. Then it does a great job, and stays put for years. I like it because it doesn't smell during application.
pompeiisneaks
Site Admin
Re: Tolex glue
Post by pompeiisneaks »
I've used what uncle doug showed on his video and it worked well for me, use contact cement on the wood itself. Coat evenly and let it start curing, it gets pretty sticky. Thne as you're ready spray the tolex or tweed with 3M spray adhesive or the like the two bond together really well. I also like that if I get a bubble, etc it's easy to peel back off and retry, gets a lot of glue stringers around but once it sets fully after a day, its STUCK. The only disadvantage is that contact cement STINKS and makes you get high as hell :D
Re: Tolex glue
Taylor Cox Amplified Nation uses Wilsonart H2O
ChopSauce
Re: Tolex glue
Post by ChopSauce »
Has anyone ever tried some glue for fiberglass wall covering ?
Scumback Speakers
Re: Tolex glue
Post by Scumback Speakers »
xtian wrote: Thu Nov 01, 2018 3:42 pm I use the water based stuff from tubesandmore.com. In the early days I put it on too lightly, and some edges lifted. Needs a good heavy coat on both surfaces, allowed to dry until tacky. Then it does a great job, and stays put for years. I like it because it doesn't smell during application.
What xtian said. I used this on my cabs for years with good results.
Scumback - Guitar Speakers That Kick Ass!
http://youtu.be/u6U30BV2kFM
sales@scumbackspeakers.com
www.scumbackspeakers.com
https://www.facebook.com/scumbackspeakers/
https://www.instagram.com/scumback_speakers/
TUBEDUDE
Re: Tolex glue
Post by TUBEDUDE »
Thanx guys, Wilsonart H2O on the way.
sonicmojo
Re: Tolex glue
Post by sonicmojo »
Just make sure you don’t put the Wilsonart or other water based stuff on any painted surfaces, especially near the edges or in humid environments, like here in Hawaii. I just made that mistake. Bare wood with some roughness is best.
Bryan
Guy77
Re: Tolex glue
Post by Guy77 »
I also use this glue. I have tried maybe 6 different types of glues for getting tolex to stick and when it comes down to Performance, Odour, Clean up and Ease of use I think its a real winner.
Cheers
Guy
amplifiednation
Re: Tolex glue
Post by amplifiednation »
I’ve covered well over a thousand cabs with Wilsonart H2O with excellent results. Kind of a pain to get though...I get it direct from them.
Amplified Nation
www.amplifiednation.com
@ampnation
jasonwhitecountry
Re: Tolex glue
This was all with the floor glue I mentioned. $8/quart, no fumes, soap & water cleanup, good open time.ImageImageImageImageImageImageImageImage
drew
Re: Tolex glue
Post by drew »
Nice work on those cabs, jasonwhitecountry. Is there a specific brand of the stuff that you use?
jasonwhitecountry
Re: Tolex glue
drew wrote:Nice work on those cabs, jasonwhitecountry. Is there a specific brand of the stuff that you use?
Only one I've tried but I'm sold on it. From Lowe's.Image
TUBEDUDE
Re: Tolex glue
Post by TUBEDUDE »
Success with WilsonArt.
