2X12 cabinet wired for 4 and 16 ohm
I have 2 8 ohm speakers in a 2X12 cabinet and wish to wire it for both 4 and 16 ohm loads using a couple of Cliff jacks. Could someone with more knowledge than I look this diagram over and see if my thinking is correct?
Randy Magee
- Tony Bones
Re: 2X12 cabinet wired for 4 and 16 ohm
I see the 4 ohm jack putting both speakers in parallel, but the 16 ohm jack connects to only one speaker.
I accomplish this with a switch.
This worked well for me in a 2-12 cab. It's only $15.95 at AES.
Dave
https://ampgarhttps://ampgarage.com/for ... w&id=53781
Dave
- Attachments
- s-h700_plug_drawing.pdf
- (35.03 KiB) Downloaded 104 times
- s-h700_front_new1_1.png (70.81 KiB) Viewed 3320 times
Anything in moderation...nothing to excess
You can get even fancier if you add a dpst switch to that panel, which breaks the connections between the two speakers. This allows the cab to be 8 ohms, by using either speaker by itself (it's slightly quieter, too)
