Jun 26, 2020 6:58 pm
Howdy all,,,,, I just took possession on this Bogen HE-10 amp, and trying to figure out what that 'G71' cable is on the far right? A speaker connect?,, and if not, how do I configure the 5 pin sockets on the left? Similar to an earlier post of mine about an amp with a 6 pin socket...
Thanks, Kenny
20200626_185149.jpg[/attachment UPDATE,,, That G71 wire is wired directly to the RCA phono jack on the side, then goes to the Phono Volume pot.... So, here's another picture of the Hot? Impedance wire connected to those 5 pin parallel sockets. The orange 500ohm, yellow 8ohm, & green 15ohm wires all go to one different lugs on one side of the tranny, and the brown 4ohm goes to a lug on the other side. So, what's hot, & what's not, where do I dangle some wires?
SPEAKER CONNECTOR QUESTION...
