Express Documents
Trainwreck schematics, designs, pictures. Only members may post files here.
Moderators: pompeiisneaks, Structo, mhuss, HeeBGB
Benetton
Re: Express Documents
Post by Benetton » Fri Mar 21, 2014 12:22 am
Ron Worley wrote:In the vein of the other two amps, I'm making a sticky (or Allyn is technically) of the pertinent Express documents.
EDIT: BOM updated 21 July 08
EDIT: BOM Rev 1.4 posted 21 Aug 08- numerous cleanup items
EDIT: Layout corrected for C3 and C4 being switched
EDIT 21 Sept 08- Updated BOM, Build guide
EDIT: 1 Nov 08 BOM Updated, all new layout drawing
EDIT: 8 Nov 08- Updated Layout to include "R" and "C" component numbers
EDIT: 23 Nov 08- Major BOM Revision, revised Voltage Chart with expected values, Corrected Layout with Heater wires from PT
EDIT: 26 Nov 08- Layout corrected for errors on the Brite switch and Presence Pot
EDIT: 29 Nov 08- Layout corrected for wrong value on R5 (had 27K, should be 2.7K
Edit 06 Dec 08- Layout corrected for mislabeled Bias pot wiper, Brite switch cap lead error, version number.
Edit 06 Dec 08- Schematic revised with corrected brite switch configuration
EDIT: 19 Jan 09- added back in erroneously omitted R10 1M # and quantity and other little stuff.
EDIT: 29 Oct 09- BOM updated
EDIT: 23 Nov 09- BOM updated
EDIT: 20 Dec 09 Layout updated with Vintage Heyboer and Pacific OT wire colors
EDIT: 26 Feb 10- 500pf brite cap is improperly labeled C8, relabeled as C6
Benetton
TrainWreck Express Building
Post by Benetton » Fri Mar 21, 2014 12:29 am
I'll start riding an trainwreck express, and I wonder if this list is updated and correct materials so that I can follow it in the purchase of items. Thank you for listening!
jazzbass
Post by jazzbass » Fri Mar 21, 2014 9:54 am
:D :D :D
franco mezzalira
Ron Worley
Post by Ron Worley » Fri Mar 21, 2014 10:15 pm
These documents have not been updated for a couple years, mainly because there appeared to be consensus that they were nearly 100% accurate based on known Wrecks. The BOM probably should be updated as prices and parts availability have surely changed in the past years. But, I don't have the time for it these days and it still serves as a good guide on parts.
Ron
JPGraphX
Hey!
Post by JPGraphX » Mon Apr 21, 2014 10:14 pm
Hi!
I'm going to build that amp. And I will update all prices and availability of parts!
But before, I need to know something. I want my Trainwreck express to work on 6V6 because I've heard that it is better for small venue. I need an amp not TOO loud.
Thanks!
JPGraphX
JPGraphX
HeeBGB
Site Admin
Post by HeeBGB » Mon Apr 21, 2014 10:44 pm
6v6's aren't going to make it much lower in volume. It will however break up a lot sooner. I prefer EL34's myself but that's me. Use an attenuator to lower the volume to usable levels.
Forum Member Sliberty has also used a shared cathode on V1 and a 12AU7 very successfully to lower some gain but he also uses 34's IIRC
JPGraphX
Post by JPGraphX » Mon Apr 21, 2014 10:51 pm
Hi!
Okay thanks for the info. There's a VVR in that build right? What do you think about a VVR on it, it should drop volume..
VVR or PPIMV ?
JP
JPGraphX
HeeBGB
Site Admin
Post by HeeBGB » Mon Apr 21, 2014 10:53 pm
The VVR is very good at dropping volume. You won't need an attenuator with a VVR. It is really a matter of taste. Some like the VVR better and some like the Airbrake.....and some like the master volume best. You need to try all of them to know which you are going to prefer
Personally I use an Airbrake BUT I don't use it to the point of bedroom levels. IMO if I can't move that much air I may as well use a headphone amp or a POD
JPGraphX
Post by JPGraphX » Mon Apr 21, 2014 10:56 pm
Okay! Thanks!
I'll need to make some reading about VVR and PPIMV ;)!
Thanks!
JP
JPGraphX
JPGraphX
Post by JPGraphX » Tue May 06, 2014 6:22 pm
Hi all!
I've started to buy my parts but I can't find some parts:
Aluminum capacitor : Mallory TC78 40uf
Aluminum capacitor : Mallory SKA100M100 10uf
Aluminum capacitor : Mallory SKA220M025 22uf
MOV / Varistor / Spike Protection: Metal oxyde AVX VE17M00151K
Thanks for your help!
JPGraphX
JPGraphX
Zippy
Post by Zippy » Tue May 06, 2014 7:05 pm
This is supposed to be a thread dedicated to Express documents - not searches for parts or build support. There are other parts of the forum for that.
Zippy
Post by Zippy » Tue May 06, 2014 7:07 pm
vibratoking
Post by vibratoking » Tue May 06, 2014 10:21 pm
+1
It would be nice if a mod could remove this stuff so that it doesn't contaminate this sticky forever.
dariez75
Post by dariez75 » Thu May 21, 2015 9:04 pm
Thanks you!!!
I wanna thank all you guys, for your support, stuff, files and more. Just this evening I've finished my brand new express, it works from the first power on.
This results are due to you in this forum. Layouts are great, simple and easy to understand. Thank a lot, appreciated
Ron Worley
Post by Ron Worley » Fri May 22, 2015 12:04 am
I'll throw him a bone..
The Mallory TC series are not that plentiful and stoopidly expensive. RJ Guitars was selling some a while back. Personally, I'd use F&T if I built another one.
The other smaller caps can be substituted with similar Mallory caps. Or try something else for flavor. These were chosen as reasonable subs for what Ken used, they are not gospel.
For the MOV, just find a similar variant, again, not gospel.
Ron
Who is online
Users browsing this forum: No registered users and 1 guest
