Moderators: pompeiisneaks , Colossal
talbany
Posts: 4679 Joined: Tue Mar 28, 2006 5:03 am
Post
by talbany » Mon Oct 01, 2018 1:17 am
See I could never get my High Plates to squeal like that (3:30) when he digs in up high.My low plates can get that no problem. Especially with a Tele
That is classic low plate response IMO
stelligan
Posts: 1444 Joined: Sat Sep 30, 2006 3:58 pm
Post
by stelligan » Tue Oct 02, 2018 7:34 pm
If you are hauling one to gigs - YES.
IMHO have always thought they enhanced bloom and sustain. Perhaps smooth out the overdrive a bit depending on your gain staging. Henry @ RedPlate built me a combo a long time ago that has send and return pots on the back for the loop - and the master on front is on a switch pot that pulls out to defeat the loop. Very quick and easy to A/B with and without loop to see how it is affecting things.
Your browser doesn't support HTML5 and this audio can't be played. You can try downloading the video instead.
*not me - Garth Webber with similar model.
jelle
Posts: 2378 Joined: Sat Feb 04, 2006 7:55 pm
Post
by jelle » Fri Oct 26, 2018 4:49 pm
To Marks OP: it cannot be a clone if it has the loop. Duh.
Posts: 2998 Joined: Sat Jan 15, 2005 8:10 am
Post
by Mark » Sat Oct 27, 2018 4:05 am
You know what I'm talking about Jelle. I refer using the Dumble circuits. If I put the amp and the Dumbleator in one chassis I'm still using Dumble circuits.
I'm surprised HAD hasn't done this with his newer amps such as the Angel Breath.
jelle
Post
by jelle » Tue Oct 30, 2018 10:41 pm
just busting your balls lol
jelle
Post
My Welagen Overdrive Special amp have the tube buffered loop built in. I agree with you.
Post
by Mark » Wed Oct 31, 2018 5:52 pm
no sweat, I wonder why HAD went down the path he did given he would possibly have ground loop issues with his amps.
67plexi
Posts: 780 Joined: Sun Apr 09, 2006 8:34 pm
Post
by 67plexi » Wed Oct 31, 2018 6:44 pm
I like the Dumbelator in a rack
Charlie Wilson
Posts: 1105 Joined: Thu Jan 23, 2014 7:32 pm
Post
by Charlie Wilson » Wed Oct 31, 2018 11:20 pm
Steve, what is the third switch on the Dumbleator? Bright for recovery send or lnfb defeat?
CW
Post
by Mark » Tue Nov 27, 2018 9:57 am
Meh, what does that reply have to do with the topic?
I didn't see any particular reference to onboard effects loops. Though I concede I skimmed through it.
Do you own the amp or are you selling them?
