Now, can someone explain why the plate voltage for V2 pentode is higher than what is coming off of the rectifier? This higher voltage stays with the socket if you swap the power tubes. The plates will change by a volt or two but not what you'd expect if the tubes were mismatched. They match almost perfectly on my Hickok.
I surely have missed it as well, but this is super nice and sounds great!
I put 3 different nfb resistors on a switch in my Small Special, along with some other taste related mods.
It does deliver the goods once you reduce the nfb and put it through the right speaker.
As for triode/pentode combos - I have to admit that I don’t like 6bm8s, I find them harsh and tiny and always missing something as opposed to 6gw8. But that’s just me and it is obviously the personal taste
