Changing the OD Input coupling cap to lower value on ODS to tighten it up
Anyone messed with various cap values to tighten up the low end on a ODS (Assuming you like some bass in your clean tone)? What cap value did you end up with? On my HRD mod I had to drop it all the way to 500pf to get it tight, but I think that might suck too much fatness out of the ODS.
Re: Changing the OD Input coupling cap to lower value on ODS to tighten it up
at the input to the V2a put 4n7, and after V2a to the drive pot you can put 2n2-4.7uF polypropylene to tighten the bass. you can stop with lowering when you loose "farting" effect in the overdrive.
Not sure where I got this one:
and I may have changed the name of the file at some point but you might well be interested in reading it.You do not have the required permissions to view the files attached to this post.
