C-lator hum
C-lator hum
I’m having some trouble with AC hum. I’m in Norway, 230 V 50 Hz. I recently got a new C-lator which injects power line hum (50 Hz, with harmonics of dominantly 150 Hz hum) into the FX loop of the OTS. To exclude other factors I’ve have disconnected every cable from the amp and C-lator, and only running the C-lator into the amp FX loop using high quality cables. Nothing in the C-lator loop. Only speaker cable from amp to the cabinet. Mains AC cords from amp and C-lator plugged into the same wall socket.
Problem is that when the C-lator is powered on, there is a bothersome hum, mainly 150 Hz. When I turn the power of the C-lator off, the hum disappears. Standby on or off on the C-lator doesn’t change a thing; hum is there. Neither does adjusting any of the levels on the C-lator. So I conclude that it is probably coming from a grounding issue, or could the PTs close proximity to the AC filtering circuit be the problem? This new C-lator has an internal PT, while the ones I’ve seen from earlier builds have them on the outside rear chassis. I also see that the filtering circuit is much closer now on the same board than on previous builds when it was separated on two different boards. This has a new layout, with radial vs axial filter caps.
Attached a picture. Any thoughts?
Re: C-lator hum
power transformer is inserting it in the chain.. or bad filtering.. maybe remount transformer totally to the end in right direction, but in fist place measure with ocilloscope residual humm in each Ub+ node
2 others liked this
Re: C-lator hum
Disconnect the mains earth ground wire from the chassis. If the hum disappears you have a ground loop. There is a simple ground isolator circuit that works well and allows the earth ground to be connected to chassis.
Re: C-lator hum
Thanks! As in unsoldering the arrowed ground wire from the AC socket shown in the picture..?
Re: C-lator hum
You could do that. May be quicker/easier to just unscrew the nut and lift that lug with the single green wire from chassis. Fasten the other lug back to chassis.
Re: C-lator hum
Yes of course! Thanks!
And if that helps, I can remove the standby/operate wiring and use that switch as a chassis ground in/out instead of a standby switch. Don't know if the standby mode is needed. I know this has been debated for years, but don't know whats the consensus these days...
Re: C-lator hum
Do you have a ground lift like the one in the picture?
G.
Re: C-lator hum
The groundwire of the two 33uF caps need to go to signalground.
Re: C-lator hum
I unscrewed the AC ground only from the chassis. Hum is still there. No change. Yes, I left the other two from the big caps still connected to ground.
So lifting the AC ground did not help. Any other ideas?
Re: C-lator hum
Does your heater circuit have a path to ground?
Re: C-lator hum
1. Did you take the paint off the chassis for all connections to the chassis? (Solder lugs, pots etc ) If not, you should do so.
2. Your powersupply grounds are not wired correct. Take a look at the layouts on this forum.
Re: C-lator hum
1. This is built and assembled by Ceriatone. I did see that the paint was removed for the one lug I did loosen. Can check the others.Richard1001 wrote: ↑Thu Mar 14, 2024 10:58 pm 1. Did you take the paint off the chassis for all connections to the chassis? (Solder lugs, pots etc ) If not, you should do so.
2. I can not see what's wrong with the PS ground wiring. I think they match Ceriatones layout, also in accordance to other layouts I've seen, but I can't see where I'm wrong. Could you be more specific? Thanks
Re: C-lator hum
The mains ground should be by itself. The first power cap ground goes to its own location and the second power cap ground goes to the star between the pots and the PCB. Check the layout in the files section.ynor wrote: ↑Thu Mar 14, 2024 11:19 pm1. This is built and assembled by Ceriatone. I did see that the paint was removed for the one lug I did loosen. Can check the others.Richard1001 wrote: ↑Thu Mar 14, 2024 10:58 pm 1. Did you take the paint off the chassis for all connections to the chassis? (Solder lugs, pots etc ) If not, you should do so.
-Dan
Re: C-lator hum
Move the ground wire of the 33 uF to the star between PCB and pots, while keeping the 47 uF at its current location together with the AC inlet ground point? Can try that tomorrow.dbharris wrote: ↑Thu Mar 14, 2024 11:25 pmThe mains ground should be by itself. The first power cap ground goes to its own location and the second power cap ground goes to the star between the pots and the PCB. Check the layout in the files section.ynor wrote: ↑Thu Mar 14, 2024 11:19 pm1. This is built and assembled by Ceriatone. I did see that the paint was removed for the one lug I did loosen. Can check the others.Richard1001 wrote: ↑Thu Mar 14, 2024 10:58 pm 1. Did you take the paint off the chassis for all connections to the chassis? (Solder lugs, pots etc ) If not, you should do so.
-Dan
