ODS 102 with 2x KT88s and built-in Dumbleator
Re: ODS 102 with 2x KT88s and built-in Dumbleator
bcmatt wrote: Tue May 14, 2024 5:09 am So, I'm just looking at the FET circuit and the Relay power supply.
If I use the Triad F-216X 12VAC supply, it looks like I use a FWB rectifier. I need a TO220 Regulator? Any recommendations? It just needs to regulate that 12VDC?
LM7812 regulator as shown on the D schematics will be fine. Looking at your FET relay connections, I see you are leaving the FET input and output floating. Better to ground the input in normal mode as shown in the eyelet board .pdf.
bcmatt
Post by bcmatt »
martin manning wrote: Tue May 14, 2024 11:13 am LM7812 regulator as shown on the D schematics will be fine. Looking at your FET relay connections, I see you are leaving the FET input and output floating. Better to ground the input in normal mode as shown in the eyelet board .pdf.
OK, thanks Martin. I think that was a combination of a late night and a lot of copy/pasting.
Does this make more sense now?
Looks good now.
didit
Post by didit »
Hello Matt --
bcmatt wrote: Tue May 14, 2024 5:09 am I need a TO220 Regulator? Any recommendations? It just needs to regulate that 12VDC?
RECOM makes a series of LM78xx replacement devices using switch-mode DC-DC regulation that I have found worth the trouble. Here is a data sheet for 1A "TO220" devices: R-78C-1_0.
There is no need to provide heatsink as even with higher input voltages are better than 90%. Concerns around SMPS noise are sensible to raise, however RECOM has broad experience supplying industrial and medical applications that have regulatory demands for clean operation and my experience to-date has been that they are quite quiet. I see other companies including TI also offering similar product but have no first-hand experience to share.
FWIW.
bcmatt
Post by bcmatt »
didit wrote: Thu May 16, 2024 5:12 pm RECOM makes a series of LM78xx replacement devices using switch-mode DC-DC regulation that I have found worth the trouble. Here is a data sheet for 1A "TO220" devices: R-78C-1_0.
Hi Didit,
Thanks for chiming in. Sorry for my ignorance, but I'm curious about the advantages it provides. Is it just the built-in heatsinking, or other things too? Is it a direct replacement in the schematic, or does it also remove some of the need for filtering?
As per your suggestion, I'm looking at this one for $15:
https://www.mouser.ca/ProductDetail/919-R-78C12-1.0
vs what I was going to get before for $2.50:
https://www.mouser.ca/ProductDetail/926-LM7812CT-NOPB
didit
Post by didit »
Hello Matt --
bcmatt wrote: Mon Jun 03, 2024 5:27 pm
Hi Didit,
Really have jumped in price since my last order some years back. I don't recall precisely, but roughly $6 each in quantity 10. At those "today" prices I'll reluctantly withdraw the suggestion.
The RECOM design, while a "pin-out" functional replacement, is unique vs classic LM linear regulator designs. There is a tiny switch-mode DC-DC supply within, and it's therefore is quite efficient -- i.e., has minimal heat output regardless of input to output voltages ratio and load current. So no heat sink required regardless; whereas the original linear regulator design might well require sinking as in worst-case will dissipate more power as heat than it delivers through to the useful circuit.
Best .. Ian
