The Much Anticipated (?) Bluesmaster Build Thread
Re: The Much Anticipated (?) Bluesmaster Build Thread
That says that the 150R from 2 isn't connected to ground.
- Raoul Duke
Measuring across the two heater leads coming out of the transformer with the bulb limiter in place gives me 6.4vac.
Marc
- Raoul Duke
I’ve actually got that resistor on pin 2 of V4. Should I move it or connect the heater bridge and see if the voltage balances out?martin manning wrote: ↑Wed May 15, 2024 1:45 pm That says that the 150R from 2 isn't connected to ground.
Marc
Do you have heater leads connected between the two sockets? If not that would explain it. I thought I saw a back/white twisted pair.
- Raoul Duke
I added the twisted pair late last night to perform sluckey’s test; but they weren’t soldered in to V4. I was measuring from the loose leads. I took them out a little while ago to basically strip back the pins and check everything methodically, piece-by-piece and start over in case I missed something small.martin manning wrote: ↑Wed May 15, 2024 1:54 pm Do you have heater leads connected between the two sockets? If not that would explain it. I thought I saw a back/white twisted pair.
Makes sense - the second ground reference wasn’t in the circuit - so it compensated by pushing all the voltage to one (grounded) side. Do I understand that correctly?
Marc
That's it. I seem to recall the same question coming up in your 102 build.Raoul Duke wrote: ↑Wed May 15, 2024 2:00 pmMakes sense - the second ground reference wasn’t in the circuit - so it compensated by pushing all the voltage to one (grounded) side. Do I understand that correctly?
- Raoul Duke
I’ll have to look and see. If so - shame on me for forgetting that lesson.
I can still remember the serial number of every weapon that was ever assigned to me (going back ~30 years now), but I can’t remember what I ate for dinner 3 days ago. Age, TBIs, too much Laphroaig, all of the above?
Onward to the PI and completion of the power section
Thanks Martin!
Thanks Martin!
Marc
- Raoul Duke
No worries! I appreciate any feedback and any opportunity to learn. It’s all very good
Marc
Yea, sorry for the diversion. If you went ahead and wired the rest of it up you'd have been fine. Hopefully the learning was worth the trip!
- Raoul Duke
Always worth it Martin; and appreciatedmartin manning wrote: ↑Wed May 15, 2024 2:16 pm Yea, sorry for the diversion. If you went ahead and wired the rest of it up you'd have been fine. Hopefully the learning was worth the trip!
Marc
- Raoul Duke
Been playing “Operation” with the main board for the last couple hours and I’m getting close to being at the next test point.
I was hoping to get some feedback on the PI lead dress if possible before I nail it. Took a gander at the Livesey site and the documented Bluesmaster builds here - most notably Ian’s (thanks Ian!) - in order to try and get it right the first time.
My concern is the wad of OT secondaries in close proximity to the pin 1 wire. Any critiques, suggestions etc. are appreciated!
Marc
- Raoul Duke
Power amp check complete - the power amp is fully operational.
B+1: 477
V5 plate: 472 biases at 38mvDc
V4 plate: 472 biased at 40mvDc
Bias pot sits a little past noon - right in the middle
V3a plate: 297
V3b plate: 294
V3 cathode: 44
Not hearing any weird noise from the PI or OT, so I guess V3b plate wire is ok where it is for now?
Plugged in my footswitch to test it and nothing is lighting up. Switches and DIN are working correctly (12v in pedal and 0v in manual) and the pedal works with my 102. Relay boards have 12v at the coil and ground continuity at the eyelets specified in the board plans. Strange.
I have to track this down before I get too much further, space to work around the relays is tight and the main board connections and HRM board make it really tight…
Still a good day though
B+1: 477
V3a plate: 297
V3b plate: 294
V3 cathode: 44
Marc
Do you mean the OT primary connections/NFB?Raoul Duke wrote: ↑Thu May 16, 2024 8:02 pm Not hearing any weird noise from the PI or OT, so I guess V3b plate wire is ok where it is for now?
- Raoul Duke
I guess that makes more sense thinking about it.
Re-checked my relay wiring at the din and switches back to the negative side of the coil and everything seems right. The runs from the relay PS board to the switches/DIN seem correct, as does the regulator side - 12v to both relays. I’m using the same Omron G5V-2 I used in my last build.
Am I testing the FS too early? I figured with 12v headed to the switches I’d be able to. I feel like I’m missing something obvious.
Marc
- Raoul Duke
Yep, obvious.
The DIN plug needed a ground reference to actually work, lol. Ran the wire back to ground 5 (as it’s labeled in the layout) and the FS magically works now.
Getting good at catching my own f-ups; now if I could get a little better at not making them…
Marc
