new build dlite
- glasman
Re: new build dlite
What part of AZ are you in?
I am in Mesa. maybe I can give you a hand.
Gary
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Re: new build dlite
Thanks guys I gonna get a camera and get some pics loaded
ASAP maybe that will help my limited knowledge of tube amp terms.
I'm still checking everything
OD not working..... gotta be simple
glasman wrote:
and if it comes down to it maybe I'll make a trip
love to check out your store and or shop
The wife loves downtown Mesa
glasman wrote:
Much appreciated glasman I'm in Parker west side of the stateWhat part of AZ are you in?
Gary
Re: new build dlite
Posting some pics
hopefully enough decent shots to analyze the problems
any info on mistakes or whatnot is very much appreciated
Re: new build dlite
I have a question.
On the master pot on the far left, where is the sheilded cable going from the middle terminal to the .02mf input cap of the PI (V3)?
I've circled what I am talking about. You ssem to have a shielded cable on the level pot and I can't tell where that goes.
Sure seems like some fat wire.
Is that the wire that came with the kit?
Re: new build dlite
Have you tried any other tubes for V1 and V2?
Sometimes it's the simple things that get us.
Re: new build dlite
Thanks for looking Structo
and I ran out of cable from the kit.
and i will try some different tubes
still befuddled by the OD and the OD switch..... just dont work
tried different switch too...gotta be in my layout
thanks
yes it is going there and it may be optical but the cable is not shieldedOn the master pot on the far left, where is the sheilded cable going from the middle terminal to the .02mf input cap of the PI (V3)?
thanks
Re: new build dlite
V2 (OD) Rk and Ck grounds are tied together but according to the pics do not seem to be grounded to the buss bar. Or did you connect the V2 Rk and Ck ground underneath the board over to the V1?
Re: new build dlite
What I'd do is disconnect the switch and connect the OD section directly.
Connect the .05uF cap directly into the 220K resistor, then the OD volume center terminal to the master volume right hand terminal.
If it works, the problem is in the switch wiring, if it doesn't you can focus on the wiring on V2.
Re: new build dlite
He has them connected by the two white wires to the buss.BobW wrote:V2 (OD) Rk and Ck grounds are tied together but according to the pics do not seem to be grounded to the buss bar. Or did you connect the V2 Rk and Ck ground underneath the board over to the V1?
How certain are you that you did all the underboard wiring correctly?
All the dotted lines on the layout are these underboard wires.
For instance, did you wire the two cathodes together?
That is the two pairs of resistor/e caps where the white wires from the board go to the buss wire.
I circled these on the layout below.
Re: new build dlite
Structo, thanks for the correction, it's what I meant to say. V2a and V2b' s Rk Ck grounds may not be connected together under the board.Structo wrote:He has them connected by the two white wires to the buss.BobW wrote:V2 (OD) Rk and Ck grounds are tied together but according to the pics do not seem to be grounded to the buss bar. Or did you connect the V2 Rk and Ck ground underneath the board over to the V1?
Re: new build dlite
double post
Re: new build dlite
Hi guys thanks for the time looking...
V2a and V2b Rk/Ck grounds are connected underneath. And wired together in pairs
Bob-i said:
Thanks I will definitely try this ASAPWhat I'd do is disconnect the switch and connect the OD section directly.
Re: new build dlite
took a break from the build....(amazing what some time in the desert can do) came back and
whataya know wiring was wrong under board
(thanks Structo you were right on)
good volume good tone. gonna do a few tweaks and
call it. gettin ready to set up a small studio
wife agrees and is helping
this forum is a great thing
thanks again to all replies
Re: new build dlite
I am so glad you got it sorted out.
It really is a good amplifier.
Sometimes the best thing to do is walk away from it and come back with a fresh perspective.
Enjoy!
Enjoy!
