Another Small Special build with a twist
Re: Another Small Special build with a twist
English is fine (me being non native speaker and even worse writer )!
Haven't tried that yet and I (would) concur that it doesn't do anything in a sense of NFB (but I think it still works as an output filter). However, I don't yet have the knowledge to confirm neither.
Anyway, I hope to have some time today evening to experiment more thoroughly.
Whatsoever amp sounds great to my ears and whatever mod I would do I will make sure it is switchable, so I can always go back and forth in a flip of a switch.
Alrighty - stupid mistake - flipped OT primaries and was creating positive feedback
Now works as expected - with current values of the resistors it is much quieter than without the NFB and frequency response, naturally, is different.
I wired it on a switch since it sounds great without the NFB as well.
I might play with the resistors (i.e. put a larger one) to decrease the volume loss and since I have few rotary switches around may wire few different capacitors to play with the frequencies.
Updated layout and thanks EaNot Made me read and learn some more. Great forum this is.
I have a Watts 17 1/2" chassis that I will try to stuff it in to. Might consider reverb and an effects loop as well. As with all my builds, it will take a while. Thanks again for the layout.
Yes, it's a cool option, I used it too.Synchu wrote: I wired it on a switch since it sounds great without the NFB as well.
PS: Slav brother?
Any ideas for adding reverb to this circuit?
see SSS or ODR sn.60RockNRollDr wrote:Any ideas for adding reverb to this circuit?
Chris
Love, peace & loudness!
AWESOME ACOUSTIC MELODY MATE!!Synchu wrote:Good point. Will try shooting something more appropriate tonight.
It is hard to resist what all this phone apps suggest
im@Omegaamps
Got my PT, OT, and choke today. I think I will use the 15 1/2" chassis instead of the 17 1/2". Looks like everything will fit without any problem.
Just tack on a 1-tube reverb. There are some schems in the file section.RockNRollDr wrote:Any ideas for adding reverb to this circuit?
Thanksgroovtubin wrote:AWESOME ACOUSTIC MELODY MATE!!Synchu wrote:Good point. Will try shooting something more appropriate tonight.
im@Omegaamps
As for reverb, I was thinking of adding an FX loop and using the digital ones, which to my current experience, I find a bit more consistent.
However, in my next (planned) build I will do a tube one and will decide. It is a relatively easy mod.
15 and 1/2" chassis should be fine depending on the PT. Mine is quite large through hole lay down (on the wider side) type and would have been very tight in a smaller chassis.
Small Special, ala Synchu, started. I went with a 2.5" X 8" X 16" chassis. A bit of a bummer cuz now I have to build another cab (I have a combo cab that the 15" chassis fits in).
This is my first return to MC iron. I thought it was kind of light duty when I bought a set a year or two ago, but I see so many folks use, and like them, that I thought I'd try again. The price is also attractive. Dirty Dawg chassis.
Should I start another thread, or is it OK to camp out on Synchu's?
Looking good telentubes
I have this same iron and thinking of doing this amp.
looking forward to your progress.
Darin
Darin
Looking excellent!
Here in Europe getting a different iron than Hammond is almost impossible (at least very expensive with shipping costs and import duties/VAT).
Or at least I don't know of any ClassicTone, Heyboer or Edcor distributors. Sowters are almost out of question price wise.
Otherwise, I think this topic is more than capable to host more than one build
Niki
Niki
