Dumble video/sound clip reference, real Dumbles only please
Matt Rae playing a Ultra-Phonix
Re: Matt Rae playing a Ultra-Phonix
FANTASTIC TONE, Howard still leads the pack doesn`t he!!
Re: Dumble video/sound clip reference, real Dumbles only please
A little blues track with Dumble ODS #94:
http://soundcloud.com/herrmarkus/forums ... arkus-pure
Just a home recording - but I think the sound is not bad:-)
Markus
Markus
Re: The Dumble video/sound clip reference, real amps only pl
boldaslove6789 wrote:I liked Max links soo much I figured we could all use a mini database for various Dumble's .............. Thanx Max!!
Stevie Ray Vaughn " Life Without You " with the "King Tone Consoul Steel String Singer" 150w:
http://www.youtube.com/watch?v=rUl0g8e4 ... re=related
Steve Kimock "Studio Sessions" with a Dumble Overdive Special 100w :
http://www.youtube.com/watch?v=XHZaYAK7 ... re=related
http://www.youtube.com/watch?v=CO5d3v7E ... re=related
http://www.youtube.com/watch?v=61hh03Lb ... 1&index=12
John Mayer Recording for Battle Studies with his
OVERDRIVE REVERB SPECIAL 100w "Stitched Up Slight Return"
http://www.youtube.com/watch?v=08qni_VAUmE
(His Steel String Singer 100w too!)
http://www.youtube.com/watch?v=CdCyZEge ... re=related
Santana "The Game of Love" ft. Michelle Branch with his Overdrive Reverb 100w w/ built in D-lator ( there's a pedal on the top of the amp that looks like an Electro Harmonix Holy Grail Reverb, Weird!!)
http://www.youtube.com/watch?v=LfBgrtPb ... re=related
Larry Carlton This is the Dumble tone my ears like to hear
http://youtu.be/9D5MMF1K6xo
http://youtu.be/sKP3pqvTplQ
Please add some More!
- boldaslove6789
Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
Can you dig it?
Are there any clips of the two types of ODSR? (reverb before OD, and reverb after OD)
Listen to Lowell George (Reverb before) Santana (Reverb after)dr. who wrote:Are there any clips of the two types of ODSR? (reverb before OD, and reverb after OD)
Did you mean Santana for Reverb before OD?
[img:400:171]http://www.santana.com/images/gear/sm_d_100ocs.jpg[/img]
I'll do the footwork on this one I was in a Lowell mood today anyways.
Showing up with a knife to a gun fight;
http://www.youtube.com/watch?v=TkVijd9g_Hk
Carlos;
http://www.youtube.com/watch?v=fQ9nQNx0KEs&ob=av2e
Nice shot of the amp as he tears into his solo. Lowell wasn't big on to much reverb that's why he loved his dumble over using a fender. Not sure that these clip really show the difference, probably more similar than different channel to channel, guitar to guitar as far as the reverb is concerned. probably more difference in the rest of the topology as far as tone.
-ER
Carlos;
-ER
- boldaslove6789
Lowel George's ODS-R has Pre OD Reverb as it was one of the first built.dr. who wrote:Did you mean Santana for Reverb before OD?
Santana's ODS-R (the new one built by Dumble, Not Dave Workman's old ODS-R) has Post Overdrive, pre PI Reverb. It was built by Dumble in 2007 (as per Santana's website),Supposedly it was modded by HAD to have HRM Overdrive too. It's in the pic above.
The attached pic is Dave Workman's old ODS-R (now owned by Santana) and was most likely also modified to have a Post Overdrive, pre PI 3 tube Reverb
Greg D.C.
Can you dig it?
Can you dig it?
2nd generation Overdrive Reverb: (Lowell George)
3 tubes (driver, return amp, mix amp,). Mix is done before the OD circuit. So you have “overdriven reverb”. By this when the note decays, the reverb gets more prominent. These amps have less gain than the usual 2nd generation ODS.
3rd generation Overdrive Reverb: Not Sure
4th generation Overdrive Reverb: (Santana #0057)
3 tubes (driver, return amp, mix amp). Reverb send is behind volume and ratio, mix before master volume. By this the reverb is a bit like an effect in the loop.
Clip 1&2
http://www.premierguitar.com/Magazine/I ... ecial.aspx
SSS:
Some with 3 tubes, some with 2 (2: mix is done by recovery after filters)
DL 300SL:
2 tubes. Mix is done by recovery after filters
DL 150W with reverb and without filters:
Similar to the 4th generation “effect in the loop” structure.
