Treble pot on RF #102
Re: Treble pot on RF #102
Where is the schematic or layout for built in Dumblelater for my extra tube socket?
didit
Post by didit »
This was the best my slow grazing has turned up -- http://ampgarage.com/forum/viewtopic.ph ... 15#p241117.
Overall it was good thread for me to build understanding ahead of building.
Best .. Ian
Yeah that was an impressive build.
aflynt
Post by aflynt »
Dunno if this helps, but here's a layout of the original version of the amp I built from the thread above.
Sonorous Sublime.pdf
I've since realized that I actually used a 1M for the master not 250k. I've made a bunch of changes to the amp since then, though.
-Aaron
Nice layout thank you.
norburybrook
Post by norburybrook »
Indeed.
Is that a belton reverb brick in there?
marcus
norburybrook wrote: Wed Aug 16, 2017 11:03 am Indeed.
marcus
Check out this link for more info on reverb. http://ampgarage.com/forum/viewtopic.ph ... 15#p241117
aflynt
Post by aflynt »
marcus
Yes. It's actually using 2 v2 Belton bricks in parallel blending two differently filtered reverbs. Sounds great for always on reverb as long as you don't have the effects loop send cranked too high. I've actually moved over to a configuration where I'm using the loop return as another gain stage and the circuit as it stands can't handle that output level without distorting. Running it at 24 Volts gives the dry signal enough headroom, but the reverb signal still will distort. I plan on revisiting this circuit when I get a chance using the V3 brick, padding/recovering the wet signal and adding some dwell.
-Aaron
