Everything You Ever Wanted to Know Part II
Re: Everything You Ever Wanted to Know Part II
some ideas for vibrato stage? seems to me without opto-res.
schematic?
schematic?
I guess it's been established that the preamp on this amp seems to be a low plate classic. Does anyone have an opinion or educated guess on what the preamp cap values are? (mid, bass, treb, clean2 coupler, OD couplers, PI, grid.)
I'm considering converting an amp that would be great for slide playing.
HRM slow????
They musta stole a bad design, mine is fast as a ferrari on the strings!odourboy wrote:Marvelous!
Jim@Omegaamps
- boldaslove6789
I attached what I've got thus far (also attached is a Visio File). Still working on it. Will post updates as I make them.
Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
Can you dig it?
Seeing this thread made me pull out the Let's Have a Ball bootleg. I've mentioned to Tony before that I would love to do one of these. Maybe now is the time. Anyone interested in a chassis?
http://www.youtube.com/watch?v=CXKQlCQKtIg
TM
TM
If there is enough interest, I , can draw up a chassis in solidworks and get a quote.
Let's get it done, chk PMsteve_p wrote:If there is enough interest, I , can draw up a chassis in solidworks and get a quote.
TM
- boldaslove6789
I might be down for one too. Maybe change the Power supply a bit (and not use can caps ). Maybe order a small batch of these Pwr trafo's with an Extra 12v Relay Tap?
Greg D.C.
Can you dig it?
Can you dig it?
Greg, I was thinking sans the cap cans as well. I also was thinking along the lines of a custom Vibrolux(same as D'lite) PT to maximize space. I haven't looked at my docs, but off the top of my head I think this is close to the last max effort Vibrolux style PT that I ordered from Heyboer. This will easily support 50W and 4-5(loop) preamp tubes.boldaslove6789 wrote:I might be down for one too. Maybe change the Power supply a bit (and not use can caps ). Maybe order a small batch of these Pwr trafo's with an Extra 12v Relay Tap?
335-0-50-335@300mA
6.3V@700mA
3.15-0-3.15 @ 5A
Revised this would allow one to try just about any duet of pwr tube, use filament resistors and still offer plenty of current for either style of relay supply.
335-0-50-335@300mA
6.3V@375mA
6.3V @ 5.5A
TM
I would use one of the JJ multistage cans..These are good sounding caps..Greg, I was thinking sans the cap cans
40-20-20-20
Greg If you want it I have the Visio Macro of the JJ somewhere..Layout looks almost as good as one of mine..
- boldaslove6789
I learned from the best "Says the young grasshopper"talbany wrote:I would use one of the JJ multistage cans..These are good sounding caps..Greg, I was thinking sans the cap cans
40-20-20-20
Sure Tony that'd be great, (E-mail me).
I'll try and finish this layout of the actual amp and then I'll make a revised layout with a more "Modern" Pwr supply.
Anybody have a schematic and/or the Pot Values of the borderline? Gil? Bueler...?
Greg D.C.
Can you dig it?
Can you dig it?
Getting a quote on 1-5 pieces of a 022723 style PT
Pri:122V
Sec: 338-0-50-338 @ 300mA
6.3V @ 450mA
6.3V @ 6A
TM
Pri:122V
6.3V @ 450mA
6.3V @ 6A
TM
Greg Here it is..Let me know if you need anything further.. For starters I would use the low plate classic layout for the stack...I'll look over some more shots of it tonight..
Good Luck young grasshopper..
Looks to have 1m A Vol input
250k 2-35A treble
100k D Linear Mid
250k 2-35A bass w/1k tail
100k-D Linear drive
100k -D Linear level
? Clerostat speed
250kA 2-35 intensity
1M A Master
1k AB Presence
TS switching as per LP Classic
4.7uf 25v bypass all around
Bassman Iron OPT 4 ohm 4K primary
and is that 200 uf on the plates..Sheesh!! Little over kill
.022 V1B coupler
.047 mid
.1 Bass
250k 2-35A treble
100k D Linear Mid
100k-D Linear drive
? Clerostat speed
1M A Master
1k AB Presence
.022 V1B coupler
.047 mid
.1 Bass
- boldaslove6789
Updates and an insanity check
Greg D.C.
Can you dig it?
Can you dig it?
