Hi Erwin,erwin_ve wrote: ↑Fri Aug 30, 2019 6:10 am Gil, I can follow your post on gain and headroom, but this is confusing;When using a larger plate resistor( like 220k or 150k) you automatically are in curved part of the load line of a 12ax7, so the upper half is different from the bottom half of the audiowave, which is harmonic distortion. Or do you draw your loadline different?" To recap, I will list again my original claims that a larger plate load resistor results in:
(b) Less harmonic distortion at the output (taken off the plate) before clipping occurs. CHECK (well, unless you have some place you can point me to that suggests otherwise)
I think irrespective of the plate resistor value, when you apply a signal at the 12AX7 grid, the output will get squashed at the top because the constant grid voltage plots (on a plate current VS voltage graph) are curved. They curve up as the plate voltage increases, so that means that the positive excursion of the plate voltage will start to level off before the negative excursion does.
Also, the higher the plate load resistor, the more horizontal the load lines will be -- in the extreme case, when the plate resistor is infinitely large, there is no AC current through the tube and the load line is horizontal. When this occurs, you can see that while moving along the load line the spacing of the constant grid voltage curves is more uniform that in the case of a vertical load line. The output is therefore more symmetrical when the load line is more horizontal, and therefore larger plate load resistors result in less harmonic distortion.
Gil
