fender Bassman 50 to #102 Robben Ford Dumble amp
Re: fender Bassman 50 to #102 Robben Ford Dumble amp
Tom,
I have been running mine with the ports open. Sounds much better to me, less bottom end. I ran my twin through it and had to turn the base down to 2 or 3 otherwise the bass was just too much.
The cab is built to the original EV specs but he did add a false wall to extend the size of the cab so it would fit my bassman head.
The cab has been tightened up and all of the joints have been caulked. I also added basket material between the speaker and baffle and the baffle and cabinet. I added a gasket to the back panel too. This sucker is air tight .
Keith
Keith
Hi Keith-
When I built my TL806s, I glued and screwed and then sealed all interior joints with epoxy. Glued and screwed the baffle in place and then epoxied that.
As you say, that sucker is tight, and solid.
Good luck with it.
Good luck with it.
Tight and solid:
This type of cab need to be air tight and solid I guess..
Need a little help. My brother barrowed my Dumble/bassman amp and cab and now he wants one. He's a carpenter and can build his own TL806 cab but wants me want me to build him an amp like mine. He doesn't need the Deep switch or the jazz / rock switch. Can someone mod a schematic with the deep and rock/jazz eliminated? The Jazz / Rock thing is confusing man. might not even use the channel or boost switching either. Just toggle the clean and overdrive. He used the overdrive channel only during practice and loved it. Kind of set it up with just a little grit and threw his Gristle King pedal at it. He was in love after that point. :}
Please Help
Keith
Please Help
Keith
Here you go: http://ampgarage.com/forum/viewtopic.ph ... 439#328439
The switch labeled Deep is really Mid-Boost, and I'd keep that, and the Mid Boost relay is actually PAB (tone stack lift).
Martin,
Some how I knew you'd chime in first. Great info and pretty much what I was looking for. I see on the schematic there is an extra switch on the center tap of the bass pot and a 68k slope resistor instead of the stock 150k. Can you shed some light on these changes?
Thanks again
http://ampgarage.com/forum/download/file.php?id=39111
Thanks again
I would not use that schematic. Look at the layout and schematic in the #102 sticky, D files section. The location is the same as you linked in the first post in this thread. Neither of those features are shown.
Martin,
Like this?
[IMG:768:1024]http://i1051.photobucket.com/albums/s430/baddog01/7B830821-E50E-4E16-8FF3-14257617873E_zpsvneipazf.jpg[/img]
here is the output section..
[IMG:768:1024]http://i1051.photobucket.com/albums/s430/baddog01/F39BA395-8454-45EC-9D94-6A10E710B0AA_zpsowmjakeb.jpg[/img]
What power transformer do you think I should use? Is there one that I could use to eliminate using an extra transformer for the channel switching section. Maybe something with 2 x 6.3V windings? Thoughts and suggestions welcome.
Keith
Like this?
Keith
Triode Electronics sells a few with a extra 5V tap
ClassicTone 40-18094 has a extra 5V tap and is a stand up style
or the 40-18073 laydown style with 5V tap and lower voltage
And member Colossal has pcb relay boards and power supplies for sale.
D
D
dcribbs1412 wrote:Triode Electronics sells a few with a extra 5V tap
D
If I use the standup power and output would I get any cross talk between the two transformers. I'm guessing that's why fender used a through the chassis power and a standup output transformer. am I wrong here?
Keith
You orient the PT and OT so there is less chance of cross talk many amps have been built with both OT and PT being standup mount type.
If you want Rock and no PAB, almost. You need to connect the top of the bass pot to the bottom of the treble pot.Baddog01 wrote:Like this?
That looks fine.Baddog01 wrote:here is the output section.
M Fowler wrote:You orient the PT and OT so there is less chance of cross talk many amps have been built with both OT and PT being standup mount type.
That does make sense. Plus id have more room in the chassis under the P/T for the filter section....
martin manning wrote:If you want Rock and no PAB, almost. You need to connect the top of the bass pot to the bottom of the treble pot.Baddog01 wrote:Like this?That looks fine.Baddog01 wrote:here is the output section.
Just Rock for this guy:}
like this?
[IMG:768:1024]http://i1051.photobucket.com/albums/s430/baddog01/93A0B266-1EFE-4C79-BD8A-C46106E4145A_zps12t7whoi.jpg[/img]
Nothing... Butt... ROCK!
Yes that's it.
Yes that's it.
