Odyssey Layout & Schematic
Bombacaototal
Re: Odyssey Layout & Schematic
Post by Bombacaototal »
tictac wrote: Thu Aug 30, 2012 4:48 am The Odyssey looks very similar an early McIntosh poweramp before they went the direct coupled route. They used a 12BH7 with 12k plate loads and a 12AU7 PI. The PI circuit isn't the same but it does have an 18k tail resistor...
interesting....
TT
I was reading that Jerry Garcia (Grateful Dead) had his amp set up with a Fender Twin Silverface (with middle control) pre amp going through a McIntosh MC2300 power amp. Sounds a bit like Dumble design, so my question is who did it first?
It looks like he first started using the McIntosh power amps in 1972: http://www.wald-electronics.com/gear_di ... story.html
ToneMerc
Post by ToneMerc »
Bombacaototal wrote: Fri Jul 21, 2017 1:33 pm
interesting....
TT
k
If I can dig it up l will post a 1956 dated schematic of a Heathkit hi-fi amp that I ran across a few years ago. It has the exact same topology and almost 100% the exact component values of the Dumble Odyssey power section, so much so that I find it truly hard to believe that it's purely a coincidence. If didn't know any better, it seems that HAD ripped the Odyssey power section directly from Heathkit amplifier kit.
TM
pompeiisneaks
Site Admin
Post by pompeiisneaks »
You got me curious so I went looking, would it have been the W6M?
http://www.freeinfosociety.com/electron ... hp?id=2380
Seems to be similar with the 12BH7 into some 6550's or was it something else?
ToneMerc
Post by ToneMerc »
pompeiisneaks wrote: Fri Jul 21, 2017 8:12 pm You got me curious so I went looking, would it have been the W6M?
No, I don't recall it being this one.
TM
Max
Post by Max »
Aaron wrote: Tue Aug 28, 2012 3:23 pmI needed a break from drawing SSS layouts so I had a go at the Odyssey. ... I couldn't make out all the values
Perhaps someone can make out all the values visible here?: https://ampgarage.com/forum/viewtopic.php?f=4&t=31595
Max
