want 2 Rok JM signature tone board layout
Re: want 2 Rok JM signature tone board layout
Inkscape, its a free Vector based graphics editor.
Great layout beasleybodyshop!
Having had a quick look at it I see that all the pots are the same value on the layout. No doubt a copy and paste typo.
Thanks for your hard work.
Cheers,
Paul.
Cheers,
Paul.
'Beauty is in the ear of the beholder'
Good eye, i will clean it up some more tonight.
Ive gone over it with Aaron's schematic in hand, and it appears to be correct, electrically. I would appreciate it if those much more intelligent than me could take a look see
Awesome! Thank you very much for doing/sharing that with us all.
I didn't catch where the grounding bus under the pots hits the chassis/ground point. Did I miss that?
Thanks again,
Dave O.
Thanks again,
Dave O.
You guys are so lucky to get a layout.
I had to build mine the hard way off the schematic which I appreciated very much.
As well as advise from TAG members and chassis/faceplate from Amplified Nation.
Gents,
I have been following all JM Sig posts with interest as i do like the sound of this amp. The pre amp looks to be closer to that of a 124 classic configuration with some slight variations ( Mid boost, 4.7uf cathode caps). The shots i have seen of an actual JM sig do not have the .001uf cap across the outer terminals of the Bass pot as per Skyline configuration?
Just an observation
Just an observation
I noticed the same thing, crafty.
- dorrisant
I put together a different layout just a few days before this one was posted... Parts (most of them) will be here tomorrow. So I am going that route.M Fowler wrote:You guys are so lucky to get a layout.
I had to build mind the hard way off the schematic which I appreciated very much.
Has anyone posted the voltages? Gotta finalize the bias circuit... Kinda curious if what I have planned will work. I am also wondering if a tube rectifier may be worth it... I have a 5v tap on the PT I'm gonna use.
Good call Crafty, I will try it both ways.
Tony I hope to get those voltages you wanted this weekend, I've been busy with so much stuff I haven't gotten back to this amp other then playing through it
- dorrisant
It's ok Mark, Tyler helped me out a while back.
Sorry I owed you big time and want to pay back.dorrisant wrote:It's ok Mark, Tyler helped me out a while back.
- dorrisant
Mark, with as much vital info as you post here, we all owe YOU.
That being said, I could use a layout that I'm pretty sure you have... I'll PM you.
What layout???
Aaron
Aaron
Layout for a bassman amp another story.Aaron wrote:What layout???
Aaron
Here is my tone board layout with values noted in working amp.
