Tweed Dee Deluxe
Re: Tweed Dee Deluxe
Hello Mark, that looks great. Yeah I am the builder in question that had a Magnetic Components OT fail. However, I think the guy I built the amp for was getting Twisted Sister with a Les Paul with the amp. I think the fact that your B+ is a bit lower on the power tubes will work to your benefit as it seems like this circuit can sound a little stiff with modern transformers. Since this circuit has a tighter output section, I am now very much convinced that the trimmer is there to unbalance(to ear) the PI and make the break up a little easier depending on guitar and player. You may get a little more high end sparkle if you use the metal film 1.5k grid stoppers. Oops, I should have read your voltage chart BEFORE I posted. Yeah, you could put a couple zener diodes on the PT CT to bring your power tube B+ down a bit or try a 5V4 rectifier(it is hard to find one that doesn't rattle).
CW
CW
Charlie, thank you and for sharing your information with all of us, very much appreciated.
I sure can use a 5V4 recto and lower the power tube plate voltage, I do have a couple of those. I thought about adding screen resistors too but didn't see anyone else doing that, any concerns for safety of the screens?
Speaking of voltage chart the expected voltages were gleaned from your posts except for a couple areas where I did not know what voltage you had.
Hello Mark, I think how "hard" the output section feels is going to depend on what kind of guitar you are using. A Les Paul may be good with the higher voltages but to me, a Fender felt a bit tight. Screen resistors I guess are a good idea in terms of tube safety, especially with the higher then stock voltages but may make the amp feel a little less open. This amp replica was the first amp I ever built about three years ago. Taking measurements and such was a little tense as the owner of the original Dumble did not want me to touch anything. My posted layout had all of the information I was able to get in a pretty short period of time.
CW
CW
Thanks for the info Charlie.
Jelle, that's the Tweed OT I'm using, I wasn't exactly worried about a dead nuts clone.jelle wrote:
...... as the alternative is a pro OT and this will change the amp
Mike
I set my PT up with a B+ goal in the range of 370-380 max with an GZ34.Charlie Wilson wrote:Hello Mark, that looks great. Yeah I am the builder in question that had a Magnetic Components OT fail. However, I think the guy I built the amp for was getting Twisted Sister with a Les Paul with the amp. I think the fact that your B+ is a bit lower on the power tubes will work to your benefit as it seems like this circuit can sound a little stiff with modern transformers. Since this circuit has a tighter output section, I am now very much convinced that the trimmer is there to unbalance(to ear) the PI and make the break up a little easier depending on guitar and player. You may get a little more high end sparkle if you use the metal film 1.5k grid stoppers. Oops, I should have read your voltage chart BEFORE I posted. Yeah, you could put a couple zener diodes on the PT CT to bring your power tube B+ down a bit or try a 5V4 rectifier(it is hard to find one that doesn't rattle).
CW
Mike
Installed the new 10k trimmer and set based on Charlie's layout trimmer readings, that worked out nicely.
Using a 5U4 until I find my 5V4 recto tube.
Great sounding amp I using a Les Paul and cab arrives this week.
Mark,
What speaker are you planning on using?
I'm using a Weber 12F125-O at this time, which I used in my original 5e3 clone. May try a WGS Veteran 30.
Good question Chip because I really have been wondering myself. In testing I have been using a 212 loaded with Mojotone BV-30V's or Dumble style 212 with EVM12L, kind of spoiled with the 212 tone/volume. Going to a single 12" will be a trial and error thing for me.CHIP wrote:Mark,
Got my cab in record time before I could get my handle and hardware order sent.
Still not sure about speaker choice.
I have a bunch of old 6V6GT's from mono block Magnatone amp and another old piece of audio equipment and they sound great in the amp.
Speaker choice...go with the one that Dumble chose. Cheap and accurate to the original.
Great looking cab Mark.
What holds the rear panels on? Velcro?
I'm very curious to hear this amp. Has anyone post a clip? I would love to hear it!!
It's cheaper if you do your own work, so I will drill holes, use flat washer under a finish washer and screw. Silly Tom.Structo wrote:Great looking cab Mark.
Have handle kit on order and I have drawers full of different style feet.
Front screws to hold baffle board are either brass or copper front, have to drill those too. Might be easier to just buy it all done for me
Well I didn't see any fasteners, which is why I asked.
Another trick I saw on some custom guitars was to use those small super magnets (neodymium?) to attach rear cover plates on the back of the guitar.
No visible fasteners.
