Dlite 22 too dark and clean mod?
zelenko
Post by zelenko »
Hello
i've built dlite 22 and it is playing great with speaker g12 65 creamback, but sometimes i find it too dark and too gainy! is there a way to get more clean from it and any way to change this dark temper? :)
Thanks in advance
ToneMerc
Re: Dlite 22 too dark and clean mod?
Post by ToneMerc »
In generalities; two or four big output tubes, bigger OT and classic tone stack would be a start.
TM
10thTx
Post by 10thTx »
You can try a 5751 or 12AY7 in V1 (clean)
You can use a 5751 in V2 (OD)
You can use a 5751 or 12AT7 in V3 (LTPI)
http://www.thetubestore.com/Resources/G ... ain-Factor
You can also consider having a 2.2uf cathode cap on V1-8 instead of 5uf.
And/or you can increase the value of the cathode resistor there.
With respect, 10thtx
dobbhill
Post by dobbhill »
Where's the "un-clean" coming from:
The preamp, the PI, or the output stage?
You can reduce the gain in the preamp with lower gain tubes.
If the output stage is distorting, you need a bigger amp.
D
There are no stupid questions, just stupid people.......
stelligan
Post by stelligan »
What ToneMerc said. If your PT can stand 6L6 tubes, put those in and rebias to 35mv each or so. 2 x 6V6 does not do clean very well....
zelenko
Post by zelenko »
Thank you all for quick reply! I have some ecc82 and 81 tubes so ill give them a try!
My transformer is classic tone for deluxe http://www.classictone.net/40-18087.html
is it possible to try 6l6 with it? and do i need to change anything or just to swap tubes and rebias?
Thanks again! :)
ToneMerc
Post by ToneMerc »
zelenko wrote: My transformer is classic tone for deluxe http://www.classictone.net/40-18087.html
The whole purpose of a D style amp is to mimic the gain structure and response of the real of the real thing, so why go through the trouble of building a Dumble 80's style circuit and install "Tweed" tubes while using the smallest BF Fender P/P transformer?
Well, you could install two KT88's and won't change the fact that you still only have an 15-20W output transformer. A pair of 6L6 will will just saturate that tiny transformer and make things worse IMHO.
This is real simple, the amp sounds small because it is small! I would install a bigger output transformer for starters.
TM
10thTx
Post by 10thTx »
If you are going to put in a larger OT and 6L6's, please be sure your PT can handle the extra current.
You've stated your using a Classictone Deluxe OT. IF you are using a Classictone Deluxe PT then your current handling may be underrated?
The CT Deluxe PT 40-18021 is only rated 100ma
The CT Deluxe PT 40-18016 is only rated 120ma
I would want a PT with minimum 140ma for using 6L6's/5881's.
I would probably try a 5751 in V1 and a 5751 in V2 and lower the clean channel cathode caps from 10uf to 5uf first. IF that didn't get the tone you're wanting then you can look into upgrading the PT & OT if needed.
rock_mumbles
Post by rock_mumbles »
As far as being dark and to dirty ... what are your preamp voltages?
Too low of preamp voltages and the amp will be dark and too dirty
angelodp
22/33
Post by angelodp »
With my 22/33 Dlite the 6L6 setup does help with the darkness and more headroom. I do long for that 4 tube big OT thing that really brings on the authentic Dumble tone. Dumbleator on my rig does help overall. Do you have one.
