Bezel for CE Chassis
The Radio Shack holder is too small for the .3" pilot light hole in the CE chassis.
www.radioshack.com/red-led-with-holder- ... 60068.html
These seem smaller than .3", as well, but I have not tried them:
https://www.tubesandmore.com/products/P-L200
https://www.tubesandmore.com/products/P-L400
5/16" is .3125" so to big for ~.3"
I've searched this board and have found nothing else. What are you guys using? Pic in this thread:
http://ampgarage.com/forum/viewtopic.ph ... d&start=15
Thanks!
Thanks!
Re: Bezel for CE Chassis
I think this is what you want: http://www.radioshack.com/radioshack-ch ... I&tab=tab2
That's the one I use as well. You want to carefully chase that panel lamp hole to remove that thick powdercoating too.martin manning wrote:I think this is what you want: http://www.radioshack.com/radioshack-ch ... I&tab=tab2
TM
A step drill bit turned by hand is just the thing.ToneMerc wrote:That's the one I use as well. You want to carefully chase that panel lamp hole to remove that thick powdercoating too.martin manning wrote:I think this is what you want: http://www.radioshack.com/radioshack-ch ... I&tab=tab2
TM
Ditto!martin manning wrote: A step drill bit turned by hand is just the thing.
TM
Thank you
Thanks, guys!
I just got a CE chassis today. Very nice.
This indicator also is .3125 dia. (5V incandescent)
https://www.alliedelec.com/search/produ ... #tab=specs
Pricey though, lens and bulb extra.
[img:400:267]https://lh6.googleusercontent.com/-UanL ... 010252.JPG[/img]
Thanks!
- glasman
I thought they had discontinued those things.martin manning wrote:I think this is what you want: http://www.radioshack.com/radioshack-ch ... I&tab=tab2
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Dunno. They seem to be available at all of the local stores.
- norburybrook
The picture in that thread looks like the standard 5 m LED chrome bezel I use which I also use on my FX pedals.
http://www.bitsbox.co.uk/index.php?main ... ts_id=1816
Or ebay
http://www.ebay.co.uk/itm/3x-5mm-Chrome ... 462965bc1e
Marcus
Or ebay
Marcus
