UP dumble for sale
Re: UP dumble for sale
Heh, Aaron. I do amps full time. Off the bench, out of my working memory!
The Hotel Hog does not have a presence control. The Presence cap is hard wired in.
That pot on the front is a Master Volume. 1M-A works well there. that 50K RA pot needed to move.... move over Rover!
jelle
www.welagen.com
jelle
www.welagen.com
Looks more like a master volume for the Vibrato channel only?
Yes, the 220K mixer resistor is lifted from the board on one end.
Yup, I think that's it . The MV is before the BMish channel's 220K mixer, in parallel with the trem pot in question. I'm gonna move mine there and see what sort of difference it makes. I imagine it could be incredibly useful this way when using and a/b to switch...
It is like this:
Have fun!
Have fun!
Exactly like that.
Nice drawing by the way.
- dorrisant
Can you tell me how you know that is correct?
Thanks for sharing Jelle! I think I have an extra relay transformer laying around and a donor silverface in need of fixing up so I may have to try this....jelle wrote:It is like this:
Have fun!
Bryan
Bryan
Yes, very nice, thanks Jelle!
Obviously the layout is for a Twin, but if you omit the Mid on the normal channel it matches the pic.dorrisant wrote:Can you tell me how you know that is correct?
Seems a waist to use the relay to switch the reverb, it would sound nice used as a PAB.
I've peeked inside Brandon's Bludophonix and built one myself out of an old Super Reverb a few years ago. This looks very similar. I'd have to check my notes to see if exact.
FYI: https://youtu.be/HgrKrhRPSBY
Thanks Jelle!
Very much appreciate your work.
D
D
- dorrisant
Jelle, sorry for sounding rude earlier... Thank you very much!
mhartman, are you saying you built a UP? Or a Hotel Hog?
Seems like there ought to be a sticky in the files section to collect D circuit mods. Can anybody do that anymore?
Add the PAB relay and change some plate values and you are in UP territory.Aaron wrote:Obviously the layout is for a Twin, but if you omit the Mid on the normal channel it matches the pic.dorrisant wrote:Can you tell me how you know that is correct?
TM
