New Build: Ceriatone Replica OTS 50W
dwietzel
Re: New Build: Ceriatone Replica OTS 50W
Post by dwietzel »
dwietzel wrote: Sat Jul 01, 2017 3:33 am
sonicmojo wrote: Sat Jul 01, 2017 12:23 am On my RG174 coax, I just push down the coax a little to bulge it out at the cut and make a gap in it with a pointy pick and pull out the inner part, no untangling needed and I never lose any strands of shield that way. It may not work with all types of coax.
That sounds perfect. I will certainly give that a try :-) Thanks!
I was able to use a small screwdriver to un-braid the shield. Also found a new method of doing the coax that cleaned things up a bit.
Dave
norburybrook
Post by norburybrook »
nice and tidy. I think Nick at Ceriatone does his coax like that with heat shrink on the ground.
Marcus
dwietzel
Post by dwietzel »
Got the ground bus for the pots wired in.
Dave
dwietzel
Post by dwietzel »
Can someone clarify what they mean by Star Ground?
Dave
drew
Post by drew »
^ A single ground point with ground wires coming into it from various directions, like the points of a star. The diagram I'm looking at shows the star ground to the rear of the power transformer. http://www.ceriatone.com/ceriatone/wp-c ... ial-V2.jpg
dwietzel
Post by dwietzel »
dwietzel wrote: Tue Jul 04, 2017 8:36 pm Can someone clarify what they mean by Star Ground?
Dave
I think I may have found out the specifics on the schematic. Can someone confirm?
Thanks,
Dave
norburybrook
dwietzel wrote: Wed Jul 05, 2017 12:43 am
Dave
Thanks,
Dave
yes, that diagram is correct, you'll see the main reservoir caps going to the star ground 4 and the others going to 1 and 2. the original diag you posted has them all going to ground 4. I'm not sure how much it matters, nik builds lots of amps and must ground them the way he shows with no problems I've never had ground issues with ODS builds except for one time with an anodised chassis not grounding properly.
M
dwietzel
Post by dwietzel »
norburybrook wrote: Wed Jul 05, 2017 8:46 am
Dave
Thanks,
Dave
M
Here is what the board looks like. I only have 2 leads for Ground coming off the board. I am trying to confirm larger caps to 4 and smaller ones to 1 or 2. Can someone verify?
Thanks,
Dave
drew
Post by drew »
I suggest doing it like the diagram you're building from says to do it.
dwietzel
Post by dwietzel »
drew wrote: Fri Jul 07, 2017 3:55 am I suggest doing it like the diagram you're building from says to do it. star ground.JPG
Thanks!
Dave
dwietzel
Post by dwietzel »
Dave
Thanks,
Dave
M
Looks like I will have both wires going to #4 star ground then.
Dave
dwietzel
Post by dwietzel »
Starting to wire up the preamp board. There is a lot of B+ wiring going over the FET Boost on the bottom of the chassis. I have seen some picture builds that just run the coax across the B+ lines. But I was wondering about laying them up and away from the B+ as in the picture.
Does it matter? What would be best?
Thanks,
Dave
Mr. dB
Post by Mr. dB »
dwietzel wrote: Sat Jul 08, 2017 2:07 am Starting to wire up the preamp board. There is a lot of B+ wiring going over the FET Boost on the bottom of the chassis. I have seen some picture builds that just run the coax across the B+ lines. But I was wondering about laying them up and away from the B+ as in the picture.
Thanks,
Dave
Why not run the coax straight across the bottom of the chasis, under the preamp board?
The DC is very well filtered by that point so there is really no worry.
dwietzel
Post by dwietzel »
Mr. dB wrote: Sat Jul 08, 2017 2:12 pm
Thanks,
Dave
Since this is only my 3rd build and my first using coax and I just wanted to make sure that I was not inducing noise by doing so.
