Larry carlton ported/sealed EVM-12-L cab made
andresound
Re: Larry carlton ported/sealed EVM-12-L cab made
Post by andresound »
This is NOT gospel... just my experience and opinion with the brands I mentioned!
ChopSauce
Post by ChopSauce »
Oh yes, I should have mentionned speaker models, also - but I feel like I am going to have hard times finding the information back.
One more note - assuming Thiele parameters were the same, as a side note - the amp was reportedly not a Dumble, and not a clone either - so maybe this can explain :?
hywelg
Post by hywelg »
I bought one of these when they were about £35 and learnt how to use it. Now its very easy indeed to knock a shell or cab together using it.
http://www.axminster.co.uk/axcaliber-do ... jig-502514
Unfortunately they are now over double the price.
norburybrook
Post by norburybrook »
that look great, at £35 I'd have bought one definitely.
My screw and glue is working well though so I'm in no immediate hurry to spend needless cash :D
your cab looks great though.
Marcus
P.S. where do you get your ply?
hywelg
Post by hywelg »
by norburybrook
From B&Q simply because they will cut the sheet free of charge, saves me getting my table saw out and enlisting help to run a heavy sheet through it. I'd prefer 15mm but they only sell 18mm. I use 15mm for the front baffle and 12mm for the rear . Baffle mounts are just softwood strips glued and screwed.
One thing I would recommend though is installing all 8 Tee nuts for the speaker mount. If you only have 4 and strip one you've got a problem. It is possible to replace one but you then risk damaging the grille cloth .
If you're ever passing through Nottingham (ideally on a Monday as we have the rehearsal studio all day so can really crank it) and have a spare hour I'd love to do a comparison to your amp/cab. I love my 2x12 with Emi Red Fang and EV and would like to compare it.
