JM/Wonderland using marshall style iron?
Homebelly
Post by Homebelly »
Long time lurker.. some time poster.
I'm doing the preliminary home work on a JM/Wonderland build using the schem and layout from this forum.
A couple years back I was getting ready to start a 69SL.
I have a chassis, Iron and tubes.
I'm wondering if the Iron I have would work if I built a JM/Wonderland with EL34's..?
I have these on hand.
http://www.classictone.net/40-18053.html
http://www.classictone.net/40-18026.html
http://www.classictone.net/40-18058.html
Also.
Would there be anything else I would need to consider to adapt layout/schem to EL34's..?
Cheers.
Guy77
Re: JM/Wonderland using marshall style iron?
Post by Guy77 »
You should be fine with that iron. One change people make with el34s is to change the screen resistors from 470 ohm to 1K to better protect the el34s.
I played my recent JM/Wonderland with el34 and it sounded great. Also be sure to wire the power tubes correctly for el34 .
It is one of those amps that sound great with both 6L6 , el34 and 6v6 tubes.
Enjoy!
Cheers
Guy
