SSS a Hartman Manning Affair
Re: SSS a Hartman Manning Affair
Congrats with the build. I might have to pick your idea with the grill cloth, looks cool
I too, would be keen to hear the Manning Filters.
Aaron
Aaron
Indeed looks great! +1 for the new filters demo
- norburybrook
excellent well done team
I love these threads.............when it's not me
Someone should do a complete layout schematic from this now I think a lot of people would like that now we know it works well.
M
M
Ok here's a video, my first one so be gentle on the quality and the playing.
Not sure it if it captures the amp, I make do another one.....
https://www.youtube.com/watch?v=snruyEdJN88
Eric
The link doesn't seem to work for me. Anyone have success?
- dorrisant
Getting an error.
Eric Great job if looks could kill
Dead link on your utube
Eric
Fixed the links, working on my side.........
Eric
Yes! The You Tube links are working now... Nice demos! Hearing the filter sweeps on both chords and on single note lines is useful. In chords, the balance between the low and high notes is easily heard, along with the effect on the trailing harmonics. In the single note lines, it's more about the harmonics on each note, and that seems to carry through when using the pedals. The filter switches don't seem to pop as you rotate them, either... Very nice! The FET is basically a clean boost, so adding some overdrive to the first stage adds a nice little bit of grit when you are plugged straight in. I can hear the presence working, and it sounds like a nice thing to have. So, a UL Dumble? What's not to like, eh? You're enjoying the result, which is great. Congratulations!
PS: Which PT do you have installed? HTS-7157... stand-up Twin Reverb/Showman unit? (I think yes, from another thread here). Plate voltage still around 480, loaded? That seems a little high for a Twin. What idle current are you running on the 6550's now?
Dreric,
Am I correct in understanding that you are using both UL setup AND Global Feedback on this build?
Sent from my SAMSUNG-SM-G920A using Tapatalk
